Tire Grip and load distribution of an A8/S8 during cornering (very very long) ...
#21
one other issue
with the later cars, the electronic thottle will close off as soon as the brake is applied, regardless of the throttle position.
i.e. if you have the throttle applied and hit the brake, the throttle closes, however if have have the brakes on, but then hit the throttle, the throttle works.
so you must get off the throttle completely, get onthe brakes, then get back on the throttle.
#22
iirc...drive-by-wire gives you three seconds before cutting throttle once you get on the brakes
trail braking should be unaffected unless you are mixing large amounts of left foot braking.
UnionGuy
9
04-30-2004 02:39 PM
ryoung
12-24-2001 04:49 PM
