Sponsored by:
Sponsored by:
Tire siping
Old 05-12-2006, 05:13 AM
New Member
Adrian410225's Avatar
Default Tire siping
I am planning on getting 4 Michelin Pilot Sport A/S and trying to see if I want the siping done. It show l alot of positive things about siping and wanted to see any of you guys had experience with siped tires.<ul><li><a href="http://www.discounttire.com/dtcs/tireSiping.dos?rcz=55427&amp;rc=MNMINT&amp;mk=AUDI &amp;yr=2001&amp;vid=010352">http://www.discounttire.com/dtcs/tireSiping.dos?rcz=55427&amp;rc=MNMINT&amp;mk=AUDI &amp;yr=2001&amp;vid=010352</a</li></u
Old 05-12-2006, 07:17 AM
skiracer's Avatar
Default I would personally leave the Pilot Sports stock, no siping.
They are a great tire, and if siping were really that great the manufacturers would do it.
Old 05-12-2006, 07:36 AM
AudiWorld Uber User
JimR's Avatar
Default 2nd
It's a fine tire. I scared the crap out of D3AEight when I first got mine, demonstrating wet condition adhesion.
New Member
Default Re: I would personally leave the Pilot Sports stock, no siping.
If you look at the link attached, it explains why MFG is not doing it.<ul><li><a href="http://www.sipers.com/sipers/siping_tests.asp.">http://www.sipers.com/sipers/siping_tests.asp.</a</li></ul>
Old 05-12-2006, 07:37 AM
New Member
Paul_A8's Avatar
Default I have the siped tires for a year, but didn't do any before and after tests .
I think when I was buying new tires I was just in the mood to waste extra $40.
Old 05-12-2006, 08:04 AM
Elder Member
ryoung's Avatar
Default Not a good idea.
The claim that "<i>siping will not adversely affect your tire's performance in any way</i>" is absolutely false. Our high performance suspension provides good feedback, and you will feel the additional flexibility of the tread blocks. When cornering aggressively in the dry, it'll feel like you're driving on marbles. In addition, that additional flexing results in additional heat in the tire. Aggressive cornering in the dry in the summer will overheat the tread and result in accelerated wear.
Siping definitely does improve traction on on ice and packed snow. If you want better winter performance, however, just do as skiracer said ... get a lower dry performance tire up front. The Michelin tires below are in order of decreasing dry traction and increasing ice traction (and siping). Go down the list and stop at the tire that best meets your needs.
Pilot Sport PS2
<img src="http://www.tirerack.com/images/tires/michelin/mi_pilotsport_ps2_ci1_l.jpg">
Pilot Sport A/S
<img src="http://www.tirerack.com/images/tires/michelin/mi_pilot_sport_as_ci1_l.jpg">
Pilot Exalto A/S
<img src="http://www.tirerack.com/images/tires/michelin/mi_pilot_exalto_as_ci1_l.jpg">
Pilot Alpine PA2
<img src="http://www.tirerack.com/images/tires/michelin/mi_pilot_alpin_pa2_h_ci1_l.jpg">
X-Ice
<img src="http://www.tirerack.com/images/tires/michelin/mi_xice_ci1_l.jpg">
In my own case, I'm switching from the Pirelli 240 Winter tire to the Pirelli PZero Nero M&amp;S because I'm unhappy with the performance trade-off that results from the siping.
Pirelli 240
<img src="http://www.tirerack.com/images/tires/pirelli/pir_winter_210_snowsport.jpg">
<img src="http://www.tirerack.com/images/tires/pirelli/pi_p_zero_nero_ms_ci1_l.jpg">
Old 05-12-2006, 10:16 AM
Angus Beef's Avatar
I have the Pirelli PZero Nero M&amp;S too, and am loving them
Old 05-12-2006, 10:53 AM
Jim II's Avatar
Default They did my P6's and the tires on my wifes Subaru. Hardly drove in the..
snow this year, but it was fantastic in the snow when I did. I haven't noticed any negatives. I don't experience the marbles feel like on a snow tire. I think that comes from the softer sidewall as much as the siping.
Old 05-12-2006, 02:00 PM
TSHong's Avatar
Also most tire companies frown on siping and will void your warranty.
Old 05-12-2006, 05:42 PM
Junior Member
TwinCitiesS8's Avatar
Default More thoughts...
I am thinking of those with the next set, I currently have Pilot Sport AS's but from what I am reading the new PZero Nero M&amp;S are getting better ratings despite being nearly half the cost. What about road noise? Are they quiet?
Quick Reply: Tire siping
