Tranny acting up,possible limp mode only in Drive,HELP!!!
Got in my car yesterday and the gear lights were all lit up. It would go into reverse after a thumping noise but when shift to drive it takes a while to get up to 55mph. It has a warranty from AAMCO from when i bought it and will expire on 2/8/09,but the back of the warranty says it "doesn't cover damage due to failure of electronic components".I'm still going to set up a time to take it to them.
How long can i drive in this condition?It's my only car.I don't have a way to get the codes.Any suggestions?
worse. It is a mechanical failure in the transmission. Search the forum for "clutch A basket".
Leaves clogging the center cowl drains and melting snow could have soaked the Trans brain. Was it stored outside when the snow came through?
Aamco will not cover that so I suggest checking on that first. Water, leaves, etc. in the area of that perforated cover aft of the intake manifold.
see http://www.audipages.com/Tech_Articles/heatac/exaporatordrains.html for a full description<ul><li><a href="http://www.audipages.com/Tech_Articles/heatac/exaporatordrains.html">instructions on how to unclog</a></li></ul>
mine has acted up lately with this cold weather lately. It will put the car in to limp mode if I don't let it warm up for a few minutes. Shutting the car off and then on clears it up and it acts like normal from then on. VAG tool shows inplas. reading at the sensor. Just in the really cool mornings.
This is the drain you unclog with a bent piece of tubing and compressed air. The one which fills with water and then you hear sloshing in your console and get droplets of water out of the vent system. It can soak the TCU and give you the Limp Mode with all the PRNDL indicators lit at once.
I cleaned mine out with a wet vac and some small hose, plus a bit of 1/4" vacuum tubing on an air jet and shop air. I added water with a pitcher, blasted it with the shop air, and sucked it out with the wet vac (getting leaves and crud along with it.) The drains started running too.
