Tranny goes to neutral when reaching4th gear and LIMP mode lights up
Hi,
My transmission is fine if I use it it the ''3'' position, but if I use it in ''4'' or ''D'', when it reaches the 4th speed it seems to switch from neutral to gear (engages violently), but never stays in gear very long (few seconds max). When it reaches 4th gear, the instrument display PRND32 lights up also(limp mode).
I get the following fault codes:
Control Module Part Number: 4D0 927 156 KA
Component and/or Version: G5 01L 4.2l4V USA D32
Software Coding: 00002
Work Shop Code: WSC 00000
3 Faults Found:
17114 - Gear Ratio Monitoring: Incorrect Gear Ratio
17119 - Gear 5: Incorrect Ratio
17087 - Brake Switch (F): Electrical Malfunction
The gear oil hasn't been changed in at least 150 000km. Maybe I should replace oil + filter
3 Faults Found:
Joona Lauri Kudjoi
03-02-2017 09:29 AM
QuattroProject90
12-18-2008 07:03 AM
