Sponsored by:
Sponsored by:
Transmission sealer.
Old 12-21-2004, 04:19 PM
tozoM8's Avatar
Default Transmission sealer.
So I took the valve body out again, and this is what I found.
<img src="http://pictureposter.audiworld.com/80919/dscn1558.jpg">
<img src="http://pictureposter.audiworld.com/80919/dscn1560.jpg">
Wait a minute, where is that red stuff that I put a week ago? It got completely washed out. So the anaerobic sealer is Not what we want. I put the paper gasket ,that I made yesterday.
Old 12-21-2004, 04:30 PM
PaulW's Avatar
Okay....and the results?
Old 12-21-2004, 04:39 PM
tozoM8's Avatar
Default I still don't have second gear.
Brake E is for the second gear and I need to do some research, why it is not breaking.
Old 12-21-2004, 04:43 PM
GDJT Allroad^2's Avatar
Yikes! ... 2nd gear may be where the gasket went
Old 12-21-2004, 05:38 PM
KaMaKaZieP -ALUMIN8-'s Avatar
Can you swap valve bodies?
tozoM8's Avatar
That is the plan for tomorrow.
Old 12-21-2004, 05:41 PM
Default hmmm
Do you have a schematic of where the fluid goes? I bet you te sealer is all caked up in 1 spot. I would take apart the tranny filter and see if there is any red stuff in the filter.
Old 12-21-2004, 05:42 PM
skiracer's Avatar
Did you use the primer, and how long did you let it cure before filling with fluid?
Old 12-21-2004, 05:57 PM
tozoM8's Avatar
Default Re: hmmm
The sealer is completely dissolved in the fluid. I found a few little spots and they were still soft like grease. It couldn't block anything.
Old 12-21-2004, 07:14 PM
Junior Member
badmyan's Avatar
Yikes is right. Post needed a warning or somthing, It's just before bed time and I read this. Oh God
Quick Reply: Transmission sealer.
