Transmission shifting to 5th and bouncing back to 4th around 65 mph
I am posting this about my mother's 98 A8 4.2. I took it on a roadtrip last weekend, and noticed it trying to shift to 5th around 65, RPMs being too low, and bouncing back to 4th, only to try again a few seconds later. The transmission shifts fine, at 75+ 5th gear is ok too.
What it seems to me is that 5th gear is too steep a gear for the speed that the car is trying to shift into it for. It is annoying and I think going to damage/wear out the transmission sooner. Are there any VAG changes that can be done to raise shift points, or software updates from the dealer to fix this?
Common problem?
Common problem?
Re: A recode to 00011 or 00001 will help, but not completely cure, this problem.
I belive it is a faulty Electronic Control Unit. Mines does the same thing and it is getting much worse, as it continuously can not locate the correct gear. Audi wants $2000 for the chip, but you can repair it or buy a used one.
Jshwon
11-21-2002 09:57 AM
