Transmission Temperature Sensor
Can anyone point me to the location of the tranny temp sensor[fluid temperature] used by the TCU to keep the TC open? (1999 A8Q)
Is there a specific wire going to the TCU? Any way to check it (resistance check?) without going underneath the car?
Pin 13 of the transmission harness connector (under the car) is the TOT sensor.
Pins 21 -22 of the TCM connector are the supply and return. (Variable resistance sensor)
Here is the bently procedure
Switch to resistance measuring range
Test step
V.A.G 1598/20
Test of
* Test conditions
Additional steps
Specification
Fault rectification if readout does not match specification
21
21 + 22
Transmission Fluid Temperature Sensor -G93-
* Ignition switched off
Test wiring between control unit and 16-pin connector => Page AUDI-D3-AT03-01-015-0301-184
* ATF temperature
approx. 20 ° C
approx. 0.83 k ? 4)
approx. 60 ° C
approx. 1.28 k ? 4)
approx. 120 ° C
approx. 1.88 k ? 4)
21 + 34
22 + 34
infinite ?
Check wiring harness in transmission; replace if necessary
21 + 54
22 + 54
infinite ?
=> Repair Manual, 5 Spd. Automatic Transmission 01L All Wheel Drive; Repair group 38
Unless a wire is broken (open) these sensors are pretty bullet proof.
CalG
Test step
V.A.G 1598/20
Test of
* Test conditions
Additional steps
Specification
21
21 + 22
* ATF temperature
approx. 20 ° C
approx. 0.83 k ? 4)
approx. 60 ° C
approx. 1.28 k ? 4)
approx. 120 ° C
approx. 1.88 k ? 4)
21 + 34
22 + 34
infinite ?
21 + 54
22 + 54
infinite ?
CalG
I was working on the cut and paste and missed the in and out at the transmission connector.
Pins 13 (orange wire) and pins 14 (White wire) are used for the temperature sense. The resistance between these two pins varies with transmission fluid temperature.
That measurement in Ohms is available at the TCM on pins 21 and 22 of the TCM connector. Violet and Black/violet wires.
Good luck!
CalG
Good luck!
CalG
Measuring block 4 Zone 1!
From the book:
>Indicated on display (example)
Display zones:
Display
Display
Designation
Group No.
zone
Read measured value block
004
ATF temperature
Selector lever position - Multi-function Transmission Range (TR) switch -F125--
21.0 ° C
P
1000
0101
Multi-function switch position
Depending on version: torque reduction or information of On-Board-Diagnosis
From the book:
Display zones:
Display
Display
Designation
Group No.
zone
004
ATF temperature
21.0 ° C
P
1000
0101
LarryF_in_Ca
06-10-2019 07:28 AM
Supradjza80
12-04-2009 11:18 PM
snowman '92 100
Audi 100 / A6 (C4 Platform)
9
11-30-2003 10:54 PM
