UPDATE: on the great car shake/shudder
#11
1. Cylinder 4 and 5 are on different banks (sides of the engine) and they are powered from different POS'.
2. I would swap POS' and try again and get the new codes.
#12
fuel/mixture issue and this can be from so many sources-the mixture can be affected by too much or too little air or too much or too little fuel.
The fuel is the easiest of these to check in the absence of a working vagcom
Swapping the POS will confirm if the problem is electrical as the codes will follow
the fact it is 4 and 5 consistently may offer clues.
You spoke of damage to number five in an earlier post?? it this a possible cause??
#13
I would have to go back and look it up, but the fuel code was for one specific bank....I bet the misfiring cylinder is on that bank.
I think he has only one misfiring cylinder, not two.
#14
said when they put it on their vag they got more codes than the 4 i had
they said, oxygen sensor was malfunctioning, i had a head gasket leakage which was soaking cylinder #4 (i think he meant #5, i knew about that) and said they would need to change out the spark plugs, even though they're about a year old!!!
i said, can't you just check the POS.. said it wasn't the POS
fine.... go ahead... well they did the above mentioned repairs..... guess what, the 4 codes were still there!!!!!!!!
he called back and left a message... said, "we think it's a bad ECU".... $hit i thought to myself.
i called him back about an hour later.... said it wasn't the ECU but now they think its the POS.... WTF!!!! "i told u guys to check the POS first" i said to him.... so now they want to charge me $377 for the POS and an hour labor (discount of 1/2 hour for my troubles), how nice of them
the damm POS part is only about $135 from Autohaus Arizona
what do i tell these guyz now... what if that damm POS is replaced and still an issue
i'm soooooo pissed that my VAG-COM wasn't working to try the POS myself... now costing me about $1500 in repairs!!!! $hit $hit $hit!!!!!!!
#15
also be well recieved by the engine.
Ask if they generated a readiness code or did basic settings before rechecking the codes
A discount would be in order given your own suggestion was ignored and later found to be faulty
#16
But all you need is vag-com and a little time to swap things around.
You had a cylinder not firing right, it could only be a few things. Bad coil pack, bad power output stage, bad ECU, bad wiring or mechanically stuck injector.
I think you figured everything out except the POS. And you need vag-com.
Good luck.
Good luck.
#19
got the bill $1499.82!!!!!!!
they replaced all 8 spark plugs $15each
they replaced O2 sensor $212.50
they replaced the POS $377
they replaced headgaskets $114
they charged me $735 labor........... WTF!!!!!
well, after getting the shock over the phone about total bill.... i was told in passing "oh, the TAPE you have on your power brake is loose, and braking is a bit hard"..... what???? what tape??? i don't even know where the power booster hose is let a lone that it was taped!!!!
well.. when i got there 7pm, unpacked my rental and put everything in my car, i started to drive... i couldn't even stop the damm car, the pedal was hard as heck to press down!!! can you believe they were going to let me drive the car home like this???!!! i could have killed myself or someone else!! i almost hit a parked car in their lot.
i put the car in reverse and called for the service manager (he was the one that cashed me out). told him WTF, "the car doesn't have brakes", he tried it himself, yeap!! told me to keep the rental, got out his cell phone and i think he called the service rep and yelled at him for not addressing the issue, said they didn't have the brake hose to replace it with.
i also noticed that when the service manager was trying to drive the car, the rear brake lights (white) were on as he was driving.
regardless.... they took the car out several times trying to get it fixed (3days) and yesterday was the first mention of a hard brake pedal. is this an attempt by them to cover up an accident to the brake line, or could the there have been a piece of tape on the line for the 3yrs i've had this car and it is now just starting to leak/loose pressue... i've got 110,000 miles on the car 60k of those i put on since i've had it.
how long would a piece of tape hold pressure anyways????
