Update on my 97 A8 Fuel Pump Issues...
Well, I finally got the fuel pump in today. What a pain in the a**, but I got it in, and everything hooked up, and the car started right away after sitting for six weeks. I backed it out of the garage, and just let it idle for a few minutes. It idled great, but then things started to take a turn for the worse. I got in the car, and I couldn't rev the engine or it would stall. The check engine light was on, and the car started to stumble and then stalled. I was able to start it everytime, but then it eventually stalled. I pulled some codes:
16684 multiple cylinder misfire
16685 cylinder one mis-fire detected
18020 Electronic control module incorrect coding
I cleared the codes, and started the car again, and got the same codes. I monitored the cylinder measuring blocks to see the mis-fires, and there were 96 mis-fires detected on cylinder one, and 23 on cylinder two before the car stalled. Help Please!
Re: Update on my 97 A8 Fuel Pump Issues...
Pulled the cylinder one coil pack out, and it was all corroded, as was the end of the spark plug. I swapped it with cylinder five, and got a cylinder 5 mis-fire. I also noticed that the the hose that attaches the coil pack to the spark plug was about an inch shorter on cylinder one than on five. Ordering a new coil pack I guess.
the pump holder wont be in the correct place or a drag hose will have moved
with these pumps it aint over till its over.
Did you follow the procedure exactly.
The foot of the pump positioning is all important
Re: the pump holder wont be in the correct place or a drag hose will have moved
I must have done it a dozen times, before it actually just felt right and went into the proper position. I did the procedure exactly how it was described. If the mis-fire was due to the pump not being seated correctly, how come I can move the mis-fire from 1 to 5?
geoff_k
14
08-13-2012 03:22 AM
