Updates on AC and stuff.... and leaking oil!
Hey, y'all!
I posted not-so-long ago that my AC was blowing hot. I found no codes using VAG-COM. When we switched the middle control to neutral or cold, ice cold air came out the center vents, but piping hot air is still coming out the driver and passenger side vents on each far side of the dash. No rhyme or reason...
Also, the drivetrain is ill. I'm going through a quart of oil every two weeks or so. I think it's blowing out the rear main when driving, since it doesn't pool up when parked but the under-engine plastic cover seems to get grimed up. I also heard that I should check the rear cam seals. Is there an easy way to do this?
Look at the timing belt procedure on audipages.....
<img src="http://www.audipages.com/Tech_Articles/enginemechanical/tbp21.JPG">
<img src="http://www.audipages.com/Tech_Articles/enginemechanical/tbp22.JPG">
<img src="http://www.audipages.com/Tech_Articles/enginemechanical/tbp23.JPG">
<img src="http://www.audipages.com/Tech_Articles/enginemechanical/tbp24.JPG"><ul><li><a href="http://www.audipages.com/Tech_Articles/enginemechanical/tbreplace0.html">Here's the procedure</a></li></ul>
RS4000
30v V6 Discussion
06-24-2007 03:36 AM
lovindaaudi
11-21-2006 06:33 PM
Pizzicato
11
12-10-2005 09:21 AM
shwndh
08-16-2004 08:29 PM
