USB KKL driver
I bought a cable from e-bay and downloaded VAG-COM 409-1 from ross-tech.com but for some reason I can't install driver for USB interface. I follow instalation instructions from the site but it seems like wizzard cannot find proper .dll file in VAG-COM folder. Any thoughts? someone experienced same?
P.S. I tried two different laptops, same result.
Thanks.
Thanks.
then go to pc control panel /system/device manager/ports and then see what port your cable is assigned to then close and return to vagcom /options and check the port is assigned to the same port# if so save and proceed if not reassign
you switch the com port. then test it. It should work. I have winxp so my setup works this way.
Link to the auction is below. With drivers from this seller mine now works on 409.1
I do now realize that the Shareware version alone will not do much - so I will be buying a license for the full version.<ul><li><a href="http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=4595285353&rd= 1&sspagename=STRK%3AMEWN%3AIT&rd=1">http ://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=4595285353&rd= 1&sspagename=STRK%3AMEWN%3AIT&rd=1<
