Using the stock GPS antenna
Hi,
The car is a -98 A8. I am trying to use the stock GPS antenna mounted on rear trunk with my Holux 236 GPSlim Bluetooth unit. I bought a suitable SMB-MMCX adapter from ebay and hooked it to the antenna.
The problem is that I am not sure if this works. The output of the module is 3 volts. Is this too low for the stock antenna?
If I measured correctly the impedance of the stock antenna is 260 ohms. Can this be correct? All ebay GPS antennas seem to be 50 ohms.
Is the stock antenna a passive GPS antenna or is it an active model (with separate power)? I believe it is passive.
waverunner
A4 (B7 Platform) Discussion
01-28-2007 11:02 AM
SurfinSilly
08-27-2002 01:34 PM
KenY
02-15-2002 11:29 PM
