Vag Remote Coding for 03 S8.....
<center><img src="http://farm3.static.flickr.com/2303/2516198908_ae0c4dd849.jpg"></center><p>I want to set the code for the features circled in the pic...
Is the code on the left the correct one?..
I did a search and came up with a bunch of posts about adding up hex numbers and such which I didnt really understand...
Is entering the circled code all I need to do?
and save it. Try the new/different features and see if they work- if so, you're good, if not, change it back to the original code and let us know and we'll help you figure out the correct code for your S8.
For example, if you want to have the "auto locking" fucntion (locks car at 15 MPH), just add 32 to your existing code. Then save.
If you want to add the "one touch" remote function, just add 4 to the existing code.
If you want to add the remote window, just add 64 to your existing number.
If you wanted to add all three, you would add 100 to your exisitng code.
Just write down your existing code first. You can always do one at a time and see if they work first. They will.
siberian
VAG-COM Discussion
05-26-2008 04:35 PM
