Vibration after going over bumpy roads around 50-60 MPH. Please Advise!!!!
Hi Guys,
Need your expert opinion regarding an issue with my 98 A8 4.2 Quattro.
Not always but almost every time while traveling around 50 to 60 MPH if I go over a bumpy area the car will start vibrating, it feels like something's loose in the front, I can feel the vibration on the brake pedal as well. If I speed up or slow down it goes away. I can drive at that speed (50-60MPH) normally with no problems but as soon as I go over some bumps it will start vibrating.
The air pressure is ok on all four tires. All the wheel nuts are very tight. None of the rims seem to be bent. The alignment seems to be ok since it doesn't pull to either side.
Any ideas or suggestions would be greatly appreciated.
cowboyA4
07-02-2008 01:26 PM
