Want to Flush Your Power Steering Fluid? Do I have some advice for you!
<img src="http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/psflush7.JPG"><ul><li><a href="http://www.audipages.com/Tech_Articles/susp_whls_brake_steer/psflush.html">Here's most of what you need to know</a></li></ul>
Unless you move the steering back and forth....maybe skiracer could comment on that one?
Even so, it has to change out a lot (more than 75%) of the fluid.
You might consider turning the wheels back and forth with the engine on. Typically, one side of the piston receives full system pressure always (its piston area is half that of the other, variable pressure side of the piston) so without flow through the pump, turning the wheel back and forth might just push dirty rack fluid into the pump then suck it back into the rack.
That's how my shop did it, and it used about 3 liters of fluid for the whole procedure.
Tom
Tom
I have not flushed my fluid yet. Soon as I get a chance to do so, I will report how effective it is.
