Water water everywhere...
My 2000 A8l was sitting out in the rain today and when I backed down the inclined driveway water cascaded out the back of my Alcantara headliner on the passenger's side at the C pillar.
I poured water into the rightside sunroof channel and got no water draining out behind the back tire...I assume that means that the rear sunroof drain on that side is plugged. Anyone ever had this problem, and what is the easiest way to access the drain or drain hose to blow air through?
Right side is easy. Open up the battery storage area and towards the front you will see..
a hose/tube which is the rear drain. It is a slip fit which is easily separated for cleaning.
HTH,
Mark
HTH,
Mark
RGa6
11
08-31-2005 06:42 PM
clAUDI
05-22-2001 02:32 PM
