Well, hopefully the my last of my annoying front suspension noise saga....
I have so far.... replaced all 8 control arms. Replaced the swaybar links with Meyle bolt thru ones. CV joint replaced. Eibach springs...(bilsteins on the way). Tierod assemblies (inner, outer) replaced. Then alignment (which is still off...dunno why. ECS did not mention any problems) Will re-align tomorrow. Still a slight clunking noise when accelerating or deccelerating. I will be pissed if the ball joints in the control arms are damaged due to all of the servicing done at multiple times. Any ideas? Subframe loose? Are there bushings in the subframe? Steering rack? (the car tracks fine minus the bad alignment. No veering after switching back to 245/45-18s)
But you have to take the whole "wheel bearing housing" off, and there are some must-replace parts in there.
And then you have to do an alignment on it.
I'm trying to figure out how to press out the bearing while it's still on the car, for when I eventually need to do mine. I bet I could rent a hydraulic ram, I just need to have the right scaffolding to push against. Hm. For that matter, I own a bottle jack...
DST
08-28-2007 05:49 PM
A4dp
07-17-2007 08:05 AM
DorK
08-01-2006 11:55 AM
