went to change my F125 swtich, and noticed oil being held into the plug by its cover. Would that ...
... cause a short?
Because the F125 switch does not look like something I want to change without a lift.
arg. Less than a week til waterfest.
TIA
TIA
After I had changed the ATF fluid. Fault codes said something about a fault in F-125 switch.
I tried to clear the codes, but the codes kept coming back. The switch was covered in oil. Then the car sat in the garage for a few days, while I fixed a couple oil leaks, also did the passenger side output seal, (it was leaking too). Now, the rear of the engine and switch is dry. Since then tranny has not gone into safe mode again, it's been about 6 months, knock on wood! I think the leaks and the fault codes were related. Good Luck
Ghostfire
12v V6 Discussion
9
05-16-2005 06:55 PM
in2audi
03-15-2003 12:01 PM
Maddog
03-23-2002 08:43 AM
