what else to replace when doing the transmission?
I'm in the process of swapping out my Torque converter for a rebuilt one. Can anyone recommend any "You should do it now" fixes? I figure I should do the cam seals. thanks
the car has 160k and the RMS was starting to seep a little. I didn't "have" to do it but didn't want to drop the tranny again.
Upper pan gasket requires the subframe to be dropped so a good time to do that too if it's leaking.
yep, changed the rear cam plugs.
I also changed all three output seals and the diff fluids at the same time since they're so accessible out of the car.
I already changed the rear o2's but no easier time as Paul suggested.
Bob
Bob
thanks guys, Are you talking about the ones by the manifold bolts? Also, any thoughts on the F125 switch. I have no problems with it, (the mirrors work in reverse). do you think it should be replaced? its kinda pricy
didn't look much easier to get to with the trans removed. I decided if I needed to replace that one, I'll just remove the intake manifold and deal with it from up top.
Bob
Bob
Merkin
09-17-2007 02:48 AM
audikillsbmw
04-14-2007 06:31 PM
sidespar
07-14-2005 09:42 AM
cgerard
12-27-2004 03:51 PM
