What is the good battery to replace OEM on 97 A8?
As long as you get a battery with a good warranty, you should have no problems. Just make sure you get the equal or greater CCA (Cold Cranking Amp) rating.
Diehard International is good
Tozo got an energizer battery that came with free jump starting. Thats a nice feature.
Also, check audipages. There is a write up on how to change the battery using an exide battery. Exide is a good brand also.
It was $ 89.99. It comes with 38 months free replacement, 84 months pro-rated, 36 months road service ( free jumpstart ) warranty.
<img src="http://pictureposter.audiworld.com/80919/dscn1109.jpg">
<center><img src="http://onestopcar.com/images/ebay/sp1700.jpg"></center><p>I was able to fit a optima yellow top in my compartment..but i went overboard with a stinger AGM battery...
Maximum Peak Discharge of 3500 amps
5-Second Cranking Output of 1700 amps
Cold Cranking Output of 1200 amps
Nominal Capacity of 72 Ah (C20 rate)
Absorbed Glass Matt (AGM) Dry Cell Technology
Gold-Plated Top Posts
Internal Resistance: 0.0035 ohms
Dimensions of 6.5" L x 13" W x 7.4" H
I picked one of these up from a distributor for like $199.99.<ul><li><a href="http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=308579132 9&ssPageName=STRK:MEWA:IT">eBay</a></li></ul>
Same battery but 1/2 the price. The only difference is that i have solid brass connectors instead of gold connectors.
