Sponsored by:
Sponsored by:
What hose is this?
Old 10-24-2008, 03:39 PM
Ali A8's Avatar
Default What hose is this?
Been finding spots under the car and could not figure out where it was coming from. Today I noticed a wet spot under the tip of the engine cover and saw this hose that has some pretty good size rips in it. Funny thing is I got an oil change last week and nobody noticed all of this. I see its an oil line I am assuming some kind of return line maybe overflow but I am guessing. Could one of you veterans please tell what it is so I can get a new one. I have parked the car for now till I fix this. Also once I change it how would you guys I recommend cleaning the area? Would one of the engine degreasers work?
Thanks.
<img src="http://pictureposter.audiworld.com/143582/img_2132.jpg">
<img src="http://pictureposter.audiworld.com/143582/img_2133.jpg">
<img src="http://pictureposter.audiworld.com/143582/img_2134.jpg">
Old 10-24-2008, 03:48 PM
diogeniS8's Avatar
Default Re: What hose is this?
<ul><li><a href="http://www.audipages.com/Tech_Articles/enginemechanical/breatherhose.html">Take a look here</a></li></ul>
Old 10-24-2008, 03:53 PM
Ali A8's Avatar
Re: thanks, dont know what I was thinking not checking there first.
Old 10-24-2008, 03:56 PM
Member
gondar's Avatar
A (crankcase oil fume)breather hose to help equalize/vent pressure between cyl banks as as the pistons thrash up and down, causing drafts and pulsations. Clean it up with carb cleaner and paper towels and put some electrical tape around it until you get a new one. It might be easier to take it off when doing this. Replace the hose clamps with conventional screw clamps unless you have special pliers.
Don't use degreaser and spray the engine with a hose.
Old 10-24-2008, 04:03 PM
Ali A8's Avatar
Default Re: thanks
wont be driving her till its fixed so wont try and repair am actually going to go get a replacement as there is an autozone right by me and audipages had a part number that will fit. thanks for letting me know not to use degreaser will get carb cleaner and a towel.
Old 10-24-2008, 04:58 PM
mAgnum8's Avatar
Check the rear ones as well, chances are if the front hose is bad....
Old 10-24-2008, 07:55 PM
Always Overcharged's Avatar
the ole famous breather hose leak huh
Old 10-24-2008, 08:53 PM
Member
audikillsbmw's Avatar
Eww...
Old 10-25-2008, 02:35 AM
Member
DutchDoofus's Avatar
Default Get a new garage!__Re: "Funny thing is I got an oil change last week and nobody noticed all of this"
Somebody doing the oil and misses THAT is frigg'n blind !!
Old 10-25-2008, 11:35 AM
Ali A8's Avatar
Re: agreed, that was the first and last time I go there.
Quick Reply: What hose is this?
