Sponsored by:
Sponsored by:
Where can I get fuel pump removal tools?
Old 10-30-2008, 09:35 AM
mAgnum8's Avatar
Old 10-30-2008, 09:58 AM
ricoblanco's Avatar
Default The only place I see as of yet
is the <a href="http://tools.audiusa.com">Workshop Tools site</a> from the Bentley. I have ordered from here before and the prices are "reasonable".
Just click the link below the password box to access the catalog. The online catalog is the third red tab on top.
The wrench 2012A is $44.
Old 10-30-2008, 10:12 AM
New Member
TwoTonic's Avatar
Default Re: The only place I see as of yet
$44 isn't bad, but the actual mechanical problem isn't that intractable either... just need a wide-spreader 'grabber' to secure to the top of the fuel delivery assembly's cap in order to unscrew. We were able to do it without the special tool by improvising, without damaging the cap. We did it with a couple of screwdrivers and a large Channel-Lock pliers.
Old 10-30-2008, 11:34 AM
ricoblanco's Avatar
Default I thought I heard of some people doing that before...
But then I thought it was a PITA to do it that way. But if it works, that's cool!
Old 10-30-2008, 12:22 PM
pkrasusky's Avatar
Default Forgive me ignoramus - is the D2 not the same as the C4 whereby one can...
...simply reach in and employ the secret "Bra Strap Snap" (TM) to the 'clips' on the top sides of the pump basekt???
Allows you to remove solely the pump itself and leave the basket in the tank.
Maybe? Would save needing them thar special toolz.
Old 10-30-2008, 01:23 PM
tozoM8's Avatar
I just used two screwdriver and a wrench between them.
Old 10-30-2008, 05:28 PM
mAgnum8's Avatar
Default WTF, the tool I need is discontinued.
Pleas explain how the lockin ring that holds the fuel delivery module can be removed with a couple of screwdrivers and a wrench. It looks like I don't have any other choice.<ul><li><a href="http://buy.equipmentsolutions.com/eqs_va/Net/ItemDetail.aspx?PartNo=3342&amp;qty=1&amp;Desc=UNI ON+NUT+WRENCH&amp;ListPrice=&amp;itemQty=-1&amp;group_id=4&amp;group_name=3&amp;cat_ID=&amp; cat_name=&amp;sub_cat_ID=&amp;sub_cat_name=&am
Old 10-30-2008, 05:54 PM
tozoM8's Avatar
Default Here. Trust me it's easy. I did it 2000 miles from home on a parking lot.
<center><img src="http://pictureposter.audiworld.com/80919/img_2126.jpg"></center><p>
Old 10-30-2008, 06:16 PM
mAgnum8's Avatar
Default tozoM8, that one's easy. I'm talking about the big black locking ring 2ice the size...
of that one. It's in the background in that same picture.
Old 10-30-2008, 06:19 PM
mAgnum8's Avatar
Default ^^^4DO 201 375A is the number on it to the left.^^^
This is the ring that needs to come out in order to remove and reinstall the fuel pump.
Quick Reply: Where can I get fuel pump removal tools?
