Wiered. Bulb warning light changes to brake light and NO ESP ABS when headlights turned on
This is wiered. I get a light warning light everytime I touch my brakes. It then goes out immediately. BUT if I turn on my headlights I get a Brake warning light and AS well as ABS and ESP lights.
If I check my lights it turns out that when I hit my brakes on the passenger side it has not lit the front indicator, or the rear tiny side light.
any suggestions please
Yes, some kind of ground path
There are ground posts in the back corners of the trunk, you have to remove the covers to get to them...I would check the connections there.
Re: You have a short in the tail light assembly. The bulb sends feedback to the other circuit.
Thanks for the info. A quick question though. As the front indicator light doesnt turn on when I brake when teh headlight is on does that mean I have two faults or does teh rear tail light also send teh signal to the front headlight?
Thanks
Thanks
Re: Yes, some kind of ground path
Hi Paul A final question
As the warning if the headlights are not on is just a light broken warning and it changes to a "brake light broken" when the headlights are turned on do you think I should check teh front indicator light 1st (as it goes on when you brake) or just concentrate on the rear tail light
Thanks
Thanks
I had this problem with my BMW. Turns out to be a known problem, the resistance
is off just enough on non BMW bulbs to cause the light to come on. I haven't had to change any Audi bulbs... similar problem?
Worth a look while you're checking.
Bob
Bob
sam06108
04-20-2015 05:22 PM
usmcB5
04-19-2009 08:06 PM
banal
11-12-2006 07:40 PM
