Is it worth it?
Greetings,
New to the forum but have been an Audi owner for the past 4 years. Had a 01 A4 2.8 5sp Quattro and now have an 01 A8L. Over the past 5 months I have replaced the fuel pump, the water pump (and of course the timing belt), rear brakes and rotors and a few other minor repairs. Almost $5K later and at 126K miles i now have issues with the cat. convertors, the ABS system and pulled my diagnostics to find this:
Chassis Type: 4D - Audi A8 D2
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,65,76
Address 01 -------------------------------------------------------
Controller: 4D0 907 560 AF
Component: 4.2l V8/5V G 0002
Coding: 07753
Shop #: WSC 02313
WAUML54DX1N005081 AUZ7Z0Y1573338
2 Faults Found:
16814 - Catalyst System: Bank 2: Efficiency Below Threshold
P0430 - 35-00 - -
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-00 - -
Readiness: 0000 0000
Address 02 -------------------------------------------------------
Controller: 4D0 927 156 DF
Component: AG5 01L 4.2l5V USA 0708
Coding: 00002
Shop #: WSC 02313
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
Address 03 -------------------------------------------------------
Controller: 4D0 907 389 E
Component: ABS/ESP allrad D46
Coding: 08397
Shop #: WSC 02313
1 Fault Found:
P1857 - 35-00 - -
I understand these cars need a lot of care and feeding, but just wanted to get a read from other members on wether or not it is worth investing more $ into this car to fix it or simply let it go. So far I have paid more in maint than I have in car pmts. Thx for letting' me complain a little.
Abzs-
Coding: 07753
Shop #: WSC 02313
2 Faults Found:
P0430 - 35-00 - -
P0102 - 35-00 - -
Coding: 00002
Shop #: WSC 02313
1 Fault Found:
P1857 - 35-00 - -
Coding: 08397
Shop #: WSC 02313
1 Fault Found:
P1857 - 35-00 - -
Abzs-
I take it "I have replaced..." means "I paid someone to replace..." If you have to make payments on a eight-year-old car (including full-coverage insurance) and you don't DIY for most repairs, it can get pretty expensive. That's why all my cars but one are 1995 vintage or older and we paid cash for the '02 S8.
I just "fixed my cat issue, same one" the post is on QW basically you need to remove the 02 sensor, trim the tin around the tip and buy some spark plug non-foulers from a local autoparts store. HELP section part # 42009 you have to use a 1/2 drill bit and drill one out.
The drilled one will be on top, the non-drilled one on bottom, screw them into the 02 bung under the car and reinstall your 02 sensor.
mine's fine now.
It's a great $5 fix.
-Richard
mine's fine now.
-Richard
Payments are small. Needed to replace a second vehicle and found this one with only 95K miles and a complete maintenance history for $12K.
mine's fine now.
-Richard
mine's fine now.
-Richard
Definitely give this a try.. remember bank 2 is the driver's side (in the US) and it's a really easy fix i've logged over 1,000 miles now and everything is still great, no CEL.
-Richard
-Richard
AudiQmann
11-01-2008 03:30 PM
Eurostile
VAG-COM Discussion
11-08-2005 06:11 PM
shoudi?
03-28-2005 07:26 AM
