Is it worth it to purchase 4 4wire universal Bosch sensors?
For 65 dollars each, or should i spend the 166 each from vwparts.com?
I was going to replace all of them for 65k miles and solder the connections on.
I believe they are tinned wires, I did what you are referring to on my last car, couldn't get it hot enough to solder.
If you were to go with a generic model, I would get some high quality in line crimp connections, crimp them and heat shrink the connection.
pw
pw
The A8's heated oxygen sensors last can last several times longer than old unheated Bosch sensors which were scheduled replacement items in some cars. And with two sensors in each exhaust stream, the computer can tell when one of them is getting unresponsive and turn on the check engine light. So I wonder why you want to change them all now. Have you had problems with one? If so, I'd be tempted to change only it.
On my A6 i used bosch's universals and just soldered the audi harness on them and it ran for a long time. Unless you think these sensors will go for much longer. When should they be changed?
dang
05-12-2008 06:14 AM
egp320i
12
09-07-2004 04:54 PM
Lurk'n
10
09-03-2002 05:14 PM
