XM Radio installation
I took the Delphi radio out of my totaled A6 and want to put it in 2000 A8. The problem is the same with the A6. I don't want to stick it to the dash cover. On the A6, I clipped it wobbly on the air vent in the middle of the dash.
Has anyone figured a way to mount one of these so it doesn't look funky and wobble around? Also, it was impossible to route the wire to the magnetic antenae. I ended up putting on top of the dash with a little piece of sticky velcro so it didn't slide around. Wires hanging around for the cassette player signal and lighter plug were ugly too.
Since a newer car with built in satelite radio isn't in my budget, is there any other after market solution for an XM radio that is less ugly?
I put mine on a stick-on upright swivel mount, mounted to wood grain ahead and to the right of the shifter and used the cassette deck interface...next best thing to direct antenna hook-up...infinitely better sound than the radio transmitter method (tune radio to receive signal). I believe I bought the swivel mount from Crutchfield, as I recall.
I routed the antenna wire straight back past the center console (partially tucked)through the ski sack, taped onto underside of trunk lid, exiting under the trunk seal below the license plate (not gonna leak water, when it exits on the underside like that), tucked behind plate and antenna mounted just behind the existing GPS nav antenna, strong stick-on velcro (body and antenna) to hold it in place, since magnet is useless on aluminum.
Not a clean, invisible install, but sounds great and am not trying to impress anyone with appearance...I did, however, paint the antenna and the wire showing on the outside of the car with touch up paint matching the car...have to be close to car to notice antenna.
xkahn
02-08-2018 10:43 AM
Michael J Santella
Q5/SQ5 MKI (8R) Discussion
16
09-18-2015 05:53 AM
xkahn
New Member Welcome Area
09-05-2015 06:20 PM
shabz
A4 (B7 Platform) Discussion
09-05-2015 12:34 PM
