When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
It’s been hard to find info on my box being the original 4spd but if anyone’s interested I did the job myself. Havnt had it too long and just ticking things off the list as it has no service history. 165,000kms on the clock, box has been rough an went limp mode for a couple days, only dropped less than 2ltrs near Black an took over 4.5ltrs back in. Used the 5spd method from Audipages but probably didn’t get it up to temp. Bought 8 ltrs an have over 3.5 left over so will dump an replace that much more as the new mixed with the old. Might get a thermometer an stick it in to get the 30-35 degrees although as it’s not my box I’m not so sure it’s the same requirement. I had to loosen an twist the right side cat to get the pan out. Drives so much better now, whatever damage is done but I’ve definitely breathed some new life into it.. Got a 00266 solenoid No:5 but hoping it was just from the low level.
