Zimmermann brake-disc to A8 ?
Re: Zimmermann brake-disc to A8 ?
I've x-drilled zimmermans on the front of my scirocco (11" G60 corrado upgrade) for years and also had them on the front/rear of my V8 quattro. They are a cheap price and never had a problem. Also, holes are small so no "x drill" vibration u get on some of the others!
I have them on my A6 with
<center><img src="http://pictureposter.audiworld.com/42580/a6-new_rotors.jpg"></center><p>PBR Ultra Cramic Pads (all four). Rotors are great but pads as good as stock pads. To bad they do not have rotors for my S8.
yep .....
this is for a '98 4.2 .... I've seen them at other online stores as well .....<ul><li><a href="http://www.autopartsworld.com/new/product_availability.asp?product_number=N1000-20480&web_brand_id=zimmermann&web_name_id= brake-disc&year=1998&web_make_id=audi&web_mo del_id=a8-quattro-v8-4-2l&x=59&y=8">htt
Re: In front and rear?
I just have them in the fronts. Have done several high speed brake applications without a problem, i.e., no cracking around the holes. But I have never tracked the car, just autocrossed it.
Re: Are rear discs .....
my A8 is a '98 so it has the solid/non-vented disc on the back. I have seen them x-drilled a while ago for the 2000-up A8 and S8 drilled. Also my '90 V8Q had big vented disc in the rears and I got Zimmermann x-drilled so they do exist just harder 2 find :/
ask and u shall receive ...
rear x-drilled zimms for vented and S8<ul><li><a href="http://www.stopshopanddrive.com/epcvsoapimc.epc?cookieID=1NM11ZTIU1NM1CCKQR&dr illid=8&subcatid=801039@@Rear+Discs+%26+Drums& amp;clientid=stopshopanddrive">http://www.stopshopanddrive.com/epcvsoapimc.epc?cookieID=1NM11ZTIU1NM1
