Sponsored by:
Sponsored by:
00819 - High Pressure Sensor (G65)
Old 06-13-2020, 03:54 PM
  #31
Giovanni Giovino 6.0+6.0TT's Avatar
Default 1/2 off....
Hello All,
I removed the 7 screws across the top, the front section of the driver's side wheel liner, the three 10mm nuts, then gently pulled out the bumper from the driver side, plenty of room to access the G65 .
I also upgraded the fog lights....
What a pita, 100% NOT plug and play.
Johnny
Old 06-15-2020, 11:17 AM
  #32
ltooz_a6_a8_q7's Avatar
Originally Posted by Giovanni Giovino 6.0+6.0TT
Hello All,
Johnny
It's nice not to have to remove the other side... Are you sure the bumper doesn't put any kind of strain on the 3 bolts on the other side?
Old 07-02-2020, 09:04 AM
  #33
maestroo's Avatar
Originally Posted by Coñdrache Costel
I tested the sensor also to another car and is working! Don't know what else to do!
Did you ever fix your problem? I have exactly the same problem on my A3 8P tfsi.
Old 07-07-2021, 05:29 AM
  #34
Danu's Avatar
Hi
I'm new at the forum and I'm also having the same symphomts on my A3 sportback from 2006.
Some months ago the A/C stopped working in a pair of times (the ECON mode was stucked at the ON position) however it recovered by itself. Then there was a third time and it never recovered so since that day the A/C is never turning on and the ECON button is always stuckeda at the ON position.
The VAG checkings showed the following:
So if you check the first error code it shows 00819 "High presure sensor short to grown"
The second error 01809 has to be with the flaps motor (driver side) interior air vent which seems to be stucked or broken.
The third one 01273 is related with the HAVOC which seems to be related with the main fan from the HAVOC which sometimes it doesn't work and after several minutes it starts working.
My mechanic doesn't have skills and knowledge to fix the issue so I will try to do it by myself.
Any help will be apreciated....
Old 07-07-2021, 06:07 AM
  #35
maestroo's Avatar
In my case, the air conditioning compressor died. I replaced it and now it works. First try to re-gas, if it still doesn't work then try to connect the compressor directly to the battery, if it does not start, it needs to be replaced.
Old 07-07-2021, 06:09 AM
  #36
Danu's Avatar
thanks for the reply, my mechanic tested the compressor and he told me it is fine, the issue is related with G65 sensor and also with the HAVOC.
Old 07-07-2021, 06:17 AM
  #37
maestroo's Avatar
Then, it's probably just pressure sensor switch. For audi a3, part number is 1K0959126E and it's cheap and very easy to replace.
Danu (07-07-2021)
Old 07-07-2021, 07:34 AM
  #38
Danu's Avatar
I hope so.... I was looking for the tools to replace it because as far as I see you must dismantle the pump or the front right wheel to have some access to it.
However there maybe with something like this tool I will be able to take it off and replace it by the new one.
Old 07-07-2021, 10:16 AM
  #39
maestroo's Avatar
What engine do you have? On 1.4 tfsi it's a 2 minute job, the sensor is located on the pipes just above the compressor.
Old 07-07-2021, 10:20 AM
  #40
Danu's Avatar
I have the TDI 140cv (BKD) engine.
As far as I know you must remove the front right wheel to acces it:
https://thewikihow.com/video_jrDRnlu0PTc
But I think that you could also access it by the top with the correct tool.
Quick Reply: 00819 - High Pressure Sensor (G65)
