04D3, Left front Bulb (it's the white light one) just went out....
#11
Hey, it isn't too easy.
We just looked at it. The passenger side would have been pretty straightforward, just a lot of fasteners to get the air box out of the way.
The drivers side, much less so. You need to pull the PS reservoir and bracket, and would have to dump the fluid to do that. It's a couple hours work, unless we're missing something.
#12
This isn't as easy as it sounds
04 A8l - I lost my Drivers side low beam Xeon coming home last week from Nashville. Ordered replacement pair just to have the spare. Got them in this week and now have the power steering reservoir 1/2 off / drained and trying to get to second larger connector on it off from the bottom. But trying to get it's bracket out is even harder. I believe it is connected somewhere way below the ABS module.
So with bracket in place I did get the door open on the low beam, but getting my hands in there isn't going so easy to twist of the ballast, I need a person with smaller hands :/
1 hour down, many to go ...
#13
#15
I replaced my driver's side one a month ago. I removed the headlight assembly and then replaced the bulb with the headlight unit removed from the car.
My light turned pink so I figured it was going to go dark real soon. I called the dealer and asked what is typical; the ballast, igniter or the bulb. They said first thing they do is replace the bulb. If that doesn't fix it, then the igniter, if still no go, then the ballast. They claim that even if the bulb was good and more needed to be replaced, the bulb would soon fail so it's best to replace it. I just replaced the bulb. Bought it at an auto parts store for $75, it beat the dealer disCOuNt price of $220. Alas, on line it would have only been $35 but what if it arrived broken? I unwrapped it at the auto parts store to verify it was unbroken.
#16
OK - Got the entire headlight assembly out, got the new bulb in but can't twist the Ballist back on. Feel like im going to break the plastic 4 tips. DO I just push hard and twist? Hate to break it.
Thanks guys, I think I'll take some pictures of reverse process and post on the tech articles.
#17
Yes, Pic Please - Amazing what has to be done to replace a common fail item
Please do post picture and a description of your process as we will all be here sooner or later. Thanks in advance.
I'm really surprised how these late model cars have made it so difficult to access something as simple as a headlight bulb. Audi is not alone on this design flaw. Perhaps the manufactures wish to generate more service trips to their dealer network, but $300-$400 to change a HID headlight is crazy. (assuming $200 parts and $100-$200 labor).
Cheers,
Cheers,
#18
Yes, all in the name of safety.
#19
Cheers,
Cheers,
Jon Lin
01-21-2008 03:33 PM
madman0
11
11-03-2001 02:32 PM
