Sponsored by:
Sponsored by:
06 A8 4.2 Start control module (Access and Start Authorization)
Old 05-09-2016, 10:18 AM
jamm220's Avatar
Default 06 A8 4.2 Start control module (Access and Start Authorization)
The D3 has been running like champ until this morning. Went on a trip down to Charlotte got home park the car on the drive. Woke up this morning, put the key in - car wont start/turn over, key not being recognized, steering lock, nothing from the cluster.....Base on my research sounds like Access and Start Authorization fault which i have seen a couple threads on. I scanned the codes after doing the hazard/highbeam procedure to "wake the care up". I clear the code that was present but still nothing.
I found good column on ebay that hasnt been taken apart (save time with installing) with key. Can i program the key using Vag com? Thank you
Old 05-09-2016, 10:22 AM
the_duke's Avatar
What code did you clear? Not enough information here for anyone to help you.
Old 05-09-2016, 11:24 AM
jamm220's Avatar
I did a auto scan and was in hurry this morning so i cleared all DTC's as some suggest doing this will allow me to start the car. I know for sure there was a code in the start authorization module (I know i should have saved it)
Old 05-09-2016, 11:49 AM
Jack88's Avatar
There is no way to program a key with VCDS. Has to be done at a dealer. If you replace the column, module, and have a new key, I think you should be good to go, IIRC.
Old 05-09-2016, 12:23 PM
jamm220's Avatar
Thanks for you reply. Im looking at this one:
http://www.ebay.com/itm/351061111265?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
..............Thought it had to key and ignition switch but it does. What are your thoughts? go with a column that comes with th ignition switch and key or go with this one and get a new key made and program. Thanks again
Old 05-09-2016, 06:10 PM
jamm220's Avatar
Monday,09,May,2016,22:09:53:30570
VCDS Version: Release 11.11.2 (x64)
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Control Module Part Number: 4E0 910 131 HW: 4E0 909 131 L
Component and/or Version: FBS AUDID3 H10 0190
Software Coding: 0410624
Work Shop Code: WSC 02311 785 00200
Additional Info: 4E0905852E ELV 1940
Additional Info: Geraet 00200
VCID: D8B978226B08CA3
1 Fault Found:
01176 - Key
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 0
Reset counter: 34
Mileage: 433376 km
Time Indication: 0
Date: 2016.03.30
Time: 00:57:28
Old 05-09-2016, 06:20 PM
storka's Avatar
Sounds like your kessy j519 module get a used one the same or later version
Swap it out but has to go to Audi dealer to reprogram or you can clone it
See my posts about kessy j519
Also steering column as stated you need new keys or get one with original key and still needs programming at Audi dealer
Old 05-09-2016, 06:29 PM
jamm220's Avatar
the J519 module is separate issue from the start module built in the steering? I was leaning towards the start module/steering column base on readings and research. Sorry if sound confusing just trying to sort this out with the right info. thanks
Old 05-09-2016, 07:17 PM
Banned
JohnnyJ A6Q's Avatar
As Storka stated,
it may be your KESSY module, there is no start module in the steering column, that is the steering lock module/motor, the kessy module under the drivers side carpet is your keyless entry authorization/start module, the KESSY, steering column, engine ECM, and key must all be from the same vehicle, you can replace any one of the units, but you must have the secret key code for both the original and replacement unit, which I have read with CARPROG, therefore you can buy used parts and read the SKC of both, then with that info you can write the replacement part with you vehicles VIN # and IMMO number, as far as ROSS-TECH not being able to program keys, It sure can, as long as the key is new never before programmed, and again you must have the SKC, I just coded 2 new Bentley 2nd gen keys with Ross-Tech.
Also, what is odd is that the fault code is dated March 30th.....
Did you try disconnecting the vehicle battery for a bit ?
Indoblaze (04-23-2022)
Old 05-09-2016, 07:27 PM
jamm220's Avatar
Originally Posted by JohnnyJ A6Q
As Storka stated,
thanks for the thorough explanation. The car is stuck on my driveway blocking my other car in the garage. Even use the emergency release, put the car in neutral still wouldn't roll back.
I have to read it a few times to get it lol. I did disconnect the battery to have it new but like I thought it was good 12.8 volts. I didn't even realize the date. Ill hunt a used kessy, hopefully that fix the problem and I don't have to remove the column
Quick Reply: 06 A8 4.2 Start control module (Access and Start Authorization)
