09 A8L Kessy Failure Help/advice
Just bought this 2009 A8, Scanned multiple time with VCDS and Abrites. Cannot access Kessy/immobilizer at all. Sometime it will connect but will not talk. I have the original key with a good battery and new car battery a with full charge. Fuses and wiring are good. Kessy will not recognize key. No dash lights at all, radio works and display will work. If i rapidly cycle the key all of the dash lights will come on, lots of clicking and lights on and off. Powered up terminal 15 and read ECM and TCM mostly communication codes stored. No sign of water damage in modules. I tried replacing mosfets on kessy and that did not work. Steering lock does not lock with terminal 15 off. Ignition lock defective when dash lights up.
My next step is to buy kessy and have it coded to car. Does anyone know of someone who has Vas and Geko account and is willing to help me with this?
Thanks,
Frank
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4
Data version: 20170721 DS276.2
Ross-Tech: Home
VIN: WAUMV94E79N002032 License Plate:
Mileage: 133600km-83015mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 13 15 16 17 19 1E 27 28 34 36
37 38 3C 42 46 47 4F 52 53 55 56 5C 61 62 65 67 6C 6F 72 76
77
VIN: WAUMV94E79N002032 Mileage: 133600km-83015miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
27-Ctrl Head, Rear -- Status: Cannot be reached 1100
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5C-Lane Maintain. -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 0010
6F-Centr. Conv. II -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels:
VCID: D5E2DA012CB9B4EE09-FFFE
Note: Excessive Comm Errors
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI USA 0040
Revision: --H01--- Serial number: 4441621
Coding: 0000002
Shop #: WSC 49027 001 1048576
VCID: A306B4D9626D1A5E37-80F6
5 Faults Found:
049446 - No Communications with Steering Angle Sender (G85)
U0126 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:10:04
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 24.0
Temperature: 26.0°C
T.B. Angle: 0.0°
049442 - No Communication with ESP (Vehicle Dynamics) Control Module
U0122 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:10:04
049448 - No Communications with Parking Brake Control Module
U0128 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:13:44
006273 - Powertrain Data Bus: Missing Message
P1881 - 000 - Acceleration Request - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:37
013093 - Power Supply Terminal 15
P3325 - 000 - Implausible - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:38
Address 03: ABS Brakes Labels:
Address 05: Acc/Start Auth. Labels:
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Shop #: WSC 02313 785 00200
VCID: A404B7C567631D664E-80F0
No fault code found.
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348E$087529574
Coding: 0000003
VCID: B3264499D28D8ADEC7-80E6
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000066856
Subsystem 3 - Serial number: 0128.05.080000000100010011ÿ
Subsystem 4 - Serial number: 010011ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000150337
Coding: 0102737
Shop #: WSC 02311 785 00200
VCID: 9C748F255F1325A6F6-80C8
7 Faults Found:
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:18
Freeze Frame:
Voltage: 11.40 V
00066 - Rear Right Footwell Heater (Z43)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:18
Freeze Frame:
Voltage: 11.50 V
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 205
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:13:59
Freeze Frame:
Bin. Bits: 00011111
00819 - High Pressure Sensor (G65)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:41
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:41
Freeze Frame:
Temperature: 24.0°C
01206 - Signal for Duration of Ignition Off Time
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:41
00565 - Rear A/C Control Head (Climatronic) (E265)
013 - Check DTC Memory
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:41
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 S HW: 4E0 907 279 S
Component: ILM Fahrer H16 0240
Coding: 0143123
VCID: B83C73B5CBEB6986F2-80EC
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000037
Shop #: WSC 02313
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00150573
Shop #: WSC 02313
2 Faults Found:
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:07:33
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 31
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:05
Address 0E: Media Player 1 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
Coding: 020000
Shop #: WSC 02399 823 56573
VCID: AB165CF9CABDD21E8F-80FE
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 M HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0160
Revision: 00000000 Serial number: AUZ4Z7H0327363
Coding: 0000100
VCID: B12A4E912891B8CEB5-80E4
3 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 2
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 07:02:39
Freeze Frame:
Voltage: 8.40 V
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 07:02:09
Freeze Frame:
Voltage: 8.40 V
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:20:44
Address 13: Auto Dist. Reg Labels:
Address 15: Airbags Labels: None
Part No SW: 4E0 910 655 F HW: 4E0 959 655 L
Component: Airbag 9.41 H01 4230
Revision: 91H01423 Serial number: 003CV00039Z7
Coding: 0532707
VCID: A91AA6F10041C00E7D-80FC
Subsystem 1 - Serial number: 63328RB403D0FCDA1
Subsystem 2 - Serial number: 63428RB403D0FBB0W
Subsystem 3 - Serial number: 63528RB403D0FCD5+
Subsystem 4 - Serial number: 63628RB403D0FCDF9
Subsystem 5 - Serial number: 63729RB403CD1917T
Subsystem 6 - Serial number: 63829RB403CD1D3D%
5 Faults Found:
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:05:10
00591 - Seat Belt Switch; Driver (E24)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 02:45:06
01217 - Side Airbag Igniter; Driver Side (N199)
001 - Upper Limit Exceeded - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 02:45:07
01742 - Igniter for Knee Airbag; Drivers Side (N295)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:04:06
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:13:55
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0410
Revision: 00H04000 Serial number: 90055080960048
Coding: 0032351
VCID: A600ADCD115FEF7650-80F2
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H01 0030
2 Faults Found:
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:07:34
02797 - Control Module for Directional Stabilization Assistance (J759)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:48
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 981 D HW: 4E0 920 981 D
Component: KOMBIINSTR. VDO H84 0620
Revision: D03 Serial number: AUDID3H5100021
Coding: 0048283
Shop #: WSC 49027 067 57207
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4E0 907 468 H
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 0200J08507802F
Coding: F5F7DF7F7F7A0E00
VCID: AD1252E134A9DC2E91-80F8
2 Faults Found:
02874 - Control Module 2 for Central Convenience (J773)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:21:32
00460 - Control Module for Display and Input; Rear (J524)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:22:31
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046002 Serial number: AUZ5ZBH8444138
Shop #: WSC 00000 000 00000
VCID: 9A78893D55275B96E4-80CE
Address 27: Ctrl Head, Rear
Cannot be reached
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000091330
Coding: 0000000
VCID: E18AFED138F1484E65-80B4
6 Faults Found:
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation
01864 - Air Outlet Motor; Rear Right (V219)
003 - Mechanical Failure
01863 - Air Outlet Motor; Rear Left (V218)
01850 - Temperature Sensor for Heated Seat; Rear Right (G95)
01849 - Temperature Sensor for Heated Seat; Rear Left (G94)
Address 34: Level Control Labels:
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 M
Component: MNS US H51 1100
Revision: 00000000 Serial number: 395EW087515390
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000921100012
Coding: 0003477
Shop #: WSC 08219 444 53385
VCID: 9D72822144092CAE01-80C8
4 Faults Found:
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:00
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:00
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:22:00
Address 3C: Lane Change Labels:
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 F
Component: Türsteuer.FS BRM005 0180
Coding: 0032364
VCID: A00CBBD5737B01462A-80F4
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 E HW: 4E0 907 289 E
Component: Komfortgeraet H10 0030
Revision: 00300010 Serial number: W040806030170
Coding: 0048686
VCID: AB165CF90ABDD21E8F-80FE
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:10:05
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:10:21
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:05:15
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:13:41
01366 - Opened Due to Crash Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:42
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000100603
Coding: 0000026
VCID: AC145FE50FB3D52686-80F8
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 11
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 05:41:13
Freeze Frame:
Voltage: 8.30 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 13
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 05:40:23
Freeze Frame:
Voltage: 8.30 V
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 206
Time Indication: 0
00474 - Control Module for Immobilizer
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:05:19
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 D
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000025343
Coding: 0010111
VCID: 9E70852D490F37B618-80CA
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 166
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:04:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 F
Component: Türsteuer.BF BRM005 0180
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000922
Shop #: WSC 00020 210 01865
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:09:53
Freeze Frame:
Voltage: 11.18 V
Count: 247
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:40
Freeze Frame:
Voltage: 10.97 V
Count: 244
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:27:47
Freeze Frame:
Voltage: 11.28 V
Count: 231
Freeze Frame:
Fault Priority: 3
Fault Frequency: 33
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:22
Freeze Frame:
Voltage: 10.66 V
Count: 242
02443 - Control Head
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00111100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 206
Time Indication: 0
Freeze Frame:
Voltage: 5.07 V
Count: 40
Address 55: Headlight Range Labels:
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 542
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 352F%087658398
Coding: 0000002
Address 5C: Lane Maintain. Labels:
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000009846
Shop #: WSC 08219 444 54679
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 2806030311
Coding: 344530393135313035412056413032383036303330333131
3 Faults Found:
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 16
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:09:36
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 40
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:12:34
Freeze Frame:
Fault Priority: 5
Fault Frequency: 10
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:08:55
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900058099
Coding: 0232125
2 Faults Found:
004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:09:08
Freeze Frame:
(no units): 255.0
Voltage: 5.70 V
(no units): 33.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 5
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:02:14
Freeze Frame:
(no units): 255.0
Voltage: 0.00 V
(no units): 27.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H46 0630
Revision: 00000000 Serial number: 00000805300124
Shop #: WSC 12336 024 394758
VCID: B4244785D7838DE6DE-80E0
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 05:40:14
Freeze Frame:
Fault Status: 00110100
Fault Priority: 5
Fault Frequency: 7
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:12
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:12
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J84111W
Coding: 1120403
VCID: DCF4CF251F9365A636-8088
8 Faults Found:
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:41
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 4
Fault Frequency: 13
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 21:31:27
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 21:36:47
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 81
Reset counter: 206
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 75
Reset counter: 206
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 206
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:41
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:31:19
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Address 6F: Centr. Conv. II
Cannot be reached
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032364
4 Faults Found:
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:19:44
02128 - Door Closing Control Module (J657)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:48:02
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 0
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:48:32
02126 - Central Locking Button; Exterior Door Handle
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:03:20
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720814901573
Coding: 0221208
6 Faults Found:
01549 - Supply Voltage for Parking-Aid Sensor
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 9
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:08:56
Freeze Frame:
Fault Priority: 4
Fault Frequency: 15
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:22:18
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:23:51
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:08:58
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:08:55
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:09:05
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 G HW: 4E0 862 335
Component: Handyvorb2 H20 1120
Revision: 00000000 Serial number: 00000005043478
Coding: 0010900
VCID: A71EA0C91655F67E6B-80F2
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 41
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 05:41:13
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 06:01:45
End----------(Elapsed Time: 03:45, VBatt start/end: 12.3V/12.2V)-----------
Thanks,
Frank
Ross-Tech: Home
77
Coding: 0000002
5 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:10:04
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 24.0
Temperature: 26.0°C
T.B. Angle: 0.0°
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:10:04
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:13:44
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:37
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:38
Coding: 4071520
Coding: 0000003
Coding: 0102737
7 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:18
Freeze Frame:
Voltage: 11.40 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:18
Freeze Frame:
Voltage: 11.50 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 205
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:13:59
Freeze Frame:
Bin. Bits: 00011111
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:41
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:41
Freeze Frame:
Temperature: 24.0°C
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:41
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 205
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:41
Coding: 0143123
Coding: 00000037
Shop #: WSC 02313
Coding: 00150573
Shop #: WSC 02313
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:07:33
Freeze Frame:
Fault Priority: 2
Fault Frequency: 31
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:05
Revision: 00000000
Coding: 020000
Coding: 0000100
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 07:02:39
Freeze Frame:
Voltage: 8.40 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 07:02:09
Freeze Frame:
Voltage: 8.40 V
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:20:44
Coding: 0532707
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:05:10
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 02:45:06
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 02:45:07
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:04:06
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:13:55
Coding: 0032351
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:07:34
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:48
Coding: 0048283
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:21:32
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:22:31
Cannot be reached
Coding: 0000000
6 Faults Found:
Coding: 4071530
Coding: 0003477
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:00
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:22:00
Coding: 0032364
Coding: 0048686
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:10:05
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:10:21
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:05:15
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:13:41
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:42
Coding: 0000026
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 11
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 05:41:13
Freeze Frame:
Voltage: 8.30 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 13
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 05:40:23
Freeze Frame:
Voltage: 8.30 V
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 206
Time Indication: 0
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:05:19
Coding: 0010111
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 166
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:04:00
Coding: 0032364
Revision: --H03---
Coding: 0000922
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:09:53
Freeze Frame:
Voltage: 11.18 V
Count: 247
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:40
Freeze Frame:
Voltage: 10.97 V
Count: 244
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:27:47
Freeze Frame:
Voltage: 11.28 V
Count: 231
Freeze Frame:
Fault Priority: 3
Fault Frequency: 33
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:22
Freeze Frame:
Voltage: 10.66 V
Count: 242
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 206
Time Indication: 0
Freeze Frame:
Voltage: 5.07 V
Count: 40
Coding: 0000002
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 16
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:09:36
Freeze Frame:
Fault Priority: 7
Fault Frequency: 40
Reset counter: 255
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:12:34
Freeze Frame:
Fault Priority: 5
Fault Frequency: 10
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:08:55
Coding: 0032364
Coding: 0232125
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:09:08
Freeze Frame:
(no units): 255.0
Voltage: 5.70 V
(no units): 33.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 166
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:02:14
Freeze Frame:
(no units): 255.0
Voltage: 0.00 V
(no units): 27.0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 05:40:14
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:12
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:00:12
Coding: 1120403
8 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:41
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 4
Fault Frequency: 13
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 21:31:27
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 21:36:47
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 81
Reset counter: 206
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 75
Reset counter: 206
Time Indication: 0
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 206
Time Indication: 0
Freeze Frame:
Invalid
Invalid
Invalid
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:17:41
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:31:19
Freeze Frame:
Term 15 Off
Reverse OFF
Count: 3
Cannot be reached
Coding: 0032364
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:19:44
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:48:02
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:48:32
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 206
Mileage: 133600 km
Time Indication: 0
Date: 2016.08.13
Time: 00:03:20
Coding: 0221208
6 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 9
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:08:56
Freeze Frame:
Fault Priority: 4
Fault Frequency: 15
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:22:18
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:23:51
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:08:58
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:08:55
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 00:09:05
Coding: 0010900
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 41
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 05:41:13
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 206
Mileage: 133602 km
Time Indication: 0
Date: 2016.08.13
Time: 06:01:45
This one is FIXED!!! Thanks from Storka for the reference, Ross-Tech for tech support and Jack from Poland for programming. Kessy was bad and a Virgin kessy was programmed and this A8L came alive. Thank you for all your help.....
Frank
Frank
Thanks in advance
Mime
04 Audi A8L 4.2L V8
Thanks in advance
Mike
04 Audi A8L 4.2L V8
killerbill
11
05-10-2019 08:59 AM
madbaz
12-12-2014 10:21 AM
shaggymatt
Audi allroad
11-17-2008 08:29 AM
