12 volt key in power on?
Im looking for 12 volt key in power on. basically if i turn on the mmi i would like to have a 12 volt power source that would also turn off when the key is removed. any help would be helpful and believe me i've searched.
Net search the D3 archives for hooking up a radar detector, a V1, an Escort, etc. and I think you will find it again. For example: https://www.audiworld.com/forums/sho....php?t=2792461 On mine, I did it behind the fuse panel instead of into the front of it, but same basic idea. You can use a voltmeter if any doubt which ones power on with ignition. Also logically you could do the same off of the similar passenger side fuse panel if you want something physically more on that side.
Last, if it's low power load like a detector, usually no worries if you tap an existing fused circuit. Obviously for more power you would need to do it differently.
B6V8Driver
01-18-2008 04:28 AM
Eric2001A4
07-09-2004 11:34 AM
