Sponsored by:
Sponsored by:
18282 - Valve for torque support mount (short +)
Old 05-28-2008, 09:58 AM
BongoCruiser's Avatar
Default 18282 - Valve for torque support mount (short +)
I'm getting this code on my 2004 A8L. Anyone ever see this before?
What does it do ?
Where is it located ?
Advice on repair ?
Thanks
Joe
Old 05-28-2008, 10:56 AM
PaulW's Avatar
Default I'm sure it has electrical power to it
The facelift D2's have motor mounts that are electric.....they power them up/down or somehow to prevent a lot of vibration to the chasis.
The torque support is the thing in the front right of the engine (passenger side) that prevents it from torquing in a clockwise/counter clockwise direction.
You have posted 18282 (VAG code), if the SAE code is: P1874, P1875 or P1876, then there is a TSB on this.....TSB 10-07-01, which basically disconnects the electrical power supply to the torque support and tells you to put a "dummy" resistor in place of it so you don't get the code. It doesn't trip the MIL, but it will be a stored code.
Or just do nothing. Disconnecting it is the same thing.
I'll email you the TSB.
Old 05-28-2008, 12:34 PM
parkrog2's Avatar
Default Re: I'm sure it has electrical power to it
Mine does the same thing every month or so. It usually will rest itself after a week. I think mine already has resister but it still does it.
Old 05-28-2008, 03:28 PM
Der Kimbo's Avatar
There is a TSB to unplug the mount and cap off the connections.
Old 05-28-2008, 05:45 PM
Mister Bally's Avatar
Default Mine has stored the same fault
Since day one. I simply ignore it as it means nothing.
Old 05-28-2008, 07:28 PM
Aarononymous's Avatar
yeah you install a resistor in place to trick the ecm, you can just ignore it, won't cause CEL
schiu
21
12-10-2023 02:44 PM
awdinut
04-18-2012 01:37 AM
S4_Me_CT
Audi Original "S" Cars
05-13-2006 12:54 PM
Audis or VWs 4Life
12-07-2004 06:37 PM
Quick Reply: 18282 - Valve for torque support mount (short +)
