2 Suspension Fault codes VCDS Any suggestions on the remedy for these
2006 Audi A8L
2 Faults Found:
yellow light stays on : green light come on and goes off. Rear of vehicle will raise to the highest level with no warning
01400 - Suspension Level Control
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 223102 km
Time Indication: 0
Date: 2016.01.13
Time: 12:09:26
01437 - Control Position not Learned
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 223103 km
Time Indication: 0
Date: 2016.01.14
Time: 08:21:34
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 143
Mileage: 223102 km
Time Indication: 0
Date: 2016.01.13
Time: 12:09:26
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 103
Mileage: 223103 km
Time Indication: 0
Date: 2016.01.14
Time: 08:21:34
AudiWorld Wiseguy
Car seems to have forgotten it's suspension level settings.
You need to first try and do a suspension level adaption and go from there. Could be as simple as a bad level sensor/connection or maybe a bad suspension ECU.
lower better!!
just adaptation and will be good.
Ross-Tech: VAG-COM: Suspension Level Control Calibration
@mishar how you lower it by adatation? And how much you can lower it? I did 25mm and cant do more
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
hymm... i did 25 mm without change coding
I was helping myself with jack... On every wheel i did like this. First adapt my car so stay strait and stock on every wheel. Then did second adaptation and on every wheel i add 25mm, the wheel goes down and it was INVALID. I put jack near the wheel and jacking it until says VALID. Save it and goes to next wheel. Take a jack from wheel and it stay 25mm lower. And with next wheel same ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Maybe with coding i will make more
Need to try...
![Big Grin](https://www.audiworld.com/forums/images/smilies/biggrin.gif)
Eddyg
01-23-2016 07:54 AM
