2007 audi A8L passenger low beam headlight out
#11
Jason,
I have a CPO and it is still covered under a warranty, but I have to pay a co-pay for the work. Anyways, I tried to do the bulb myself and got it out and put back together. Just to find out that the dealer changed out the ballast. In the end, in my case I should have just let them do the job.
In your case you would have to either take out both bulbs to see if that works or you would have to change the ballast. Hope this helps
#13
I am having intermittent headlight trouble on my passenger side as well on my 2004 A8L. I have replaced the bulb, swapped the ignitor side to side, and still have no luck. Does anyone have any suggestions as to what else to check? I see from Bentley's wiring diagrams there may be a relay behind the instrument panel, does anyone have a hint as to how to access this relay? I am at a loss as to where to look next.
Thanks, Tim
Thanks, Tim
#14
slightly on-topic:
I struggled immensely on the 1st one trying to get the little inside 'box' twisted back on the back of the bulb. I finally noticed 3 tiny little 'nubs' on the mounting face of the new bulbs. They were maybe .01" high and .01"dia. I took an exacto and cut them off. I guess that was the problem, because I got that 'box' to finally twist on.
Moral of the story: compare the dimensions and features of your new bulbs very carefully before trying to install them. I was almost ready to send them back.
These cars are somewhat over engineered
Tim 2004 A8L
#15
Thanks, Tim
Thanks, Tim
Turned out, there were some codes stored in the DTC and once they were cleared out, I haven't experienced the issue again. Apparently, before I bought the car, someone had let the battery die down and this caused some codes to throw and this caused all of the headlamp issues.
All's good now.
#16
Those little nubs weren't on the OEM bulbs, just the aftermarket ones so it's not an Audi engineering feature. They seemed to not allow the ignitor to move in that last .01" so the 3 tabs could engage.
I also noticed the OEM bulbs had more support in the form of a metal 'tripod' that decreased much of the cantilever on the bulb. The aftermarket ones were just supported at the base of the bulb. For $14, if they last a year, it's worth the money.
#17
Went in to dealer today and they tested everything and determined that the bulbs were on their last legs. This is their explanation for why lights were working only sometimes. I'm not sure I buy it, but it was covered under CPO warranty, so no harm no foul. I'll give it a twirl for now and cross my fingers.
#18
Can you please elaborate? I have been experiencing some intermittent headlight problems also on the passenger side. In a nutshell, sometimes the headlight works and other times it does not and I get bulb out warning. The fact that it works sometimes makes me think it is NOT the bulb, but rather the ballast. I know there was some issues with vibration with this assembly, but that is hard to prove for sure.
Basically I'm wondering how they diagnosed you needed to replace the ballast? What did they charge exactly? Thanks in advance.
