2007 D3 S8 Interior LED brightness adjustment
Is there any way (VAG-COM) to adjust the brightness of the interior LED lights? I know that on the D4 they can be adjusted via VAG-COM. My LEDs are nice but they are dim.
Also, is there any way to keep the under dash footwell lights on all the time along with the side pocket lights?
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
While that also affects the brightness of the dome lights when in middle "door" mode, you can double tap the dome light off button to turn that off and turn the brightness all the way up for the remaining LED accent lights.
I've done that. It seems that the only tie I see the LEDs on the door is when I'm driving in complete darkness. If I have any kind of exterior light e.g. Miami city lights, they are non-existent. I thought maybe I could adjust them a little brighter.
Thank you
Thank you
When the D4 first came out, the interior lighting was referred to as ***** house look BTW given its brightness, the various light strips, etc. D3 is more restrained from owning both.
