View Poll Results: Which brand of spacers would you go with?
Voters: 7. You may not vote on this poll
20mm rear spacers: H&R, ECS or Eibach?
#11
20mm Bolt On Rears with Standard OEM Wheel Size and ET hit the Sweet Spot. 15mm Hubcentric Non-Bolt On Front only because the the 12mm or Less had much smaller Hubcentric Lips. I didn't want to deal with Balance Issues not did I want Suspension Support Issues on the Front so my compromise was 15mm. Net, Aggression with Style and no Suspension Issues other than what was associated with the Accident which leaves a Wheel Bearing as Final Correction from the Mis-Hap! Net, base selection on Wheel Size, Aggressive Taste, and your preference then everything else is contrary to belief. Good luck and laters,
#12
Thank you everyone answering my questions - I do appreciated it.
I've decided to go with ECS spacers - 15mm front / 20mm rear.
Will post pictures as soon as they are installed.
Thanks again.
Thanks again.
arnick'02-6spd
Audi allroad
09-04-2007 07:15 PM
TTTEXAN
05-14-2005 09:47 AM
