A8 2004 Airbag light on - repair kit installed, 5K0998582
Airbag light on. Was diagnosed by dealer that passenger seat needs repair kit installed, 5K0998582. A few short wires
Question: Anyone has done this and can help me to locate where the wires go? Do I need to open up the passenger seat in the back, site ???
Check your own tread for the answers.
can you give me a few more details?
Thanks
We already spent the time and did you the courtesy of providing good info there. Me included.
And to be clear, you are on the WRONG track here with the opening the seat back stuff. Use the down arrow and catch back up.
your help is appreciated.
Before you use those wires find the yellow harness under the seat and clean/spray the contacts. Those wires are for hard wiring instead of a harness. Once you do that you can't disconnect it in case that you have to remove your seat.
Thank you - I did clean etc the yellow yellow harness cable under the seat. Light still on - does it need to be reset by shop to see if that worked, or could it go off if its fixed?
Yes, you will have to clear the codes with VCDS or any scan tool than can access your ABS data.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
N'Syncro
33
02-16-2020 03:12 PM
ECS Tuning-Audi
09-02-2015 11:39 AM
ECS Tuning-Audi
09-01-2015 12:25 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
