Adaptive headlight malfunction
It has been raining here for a few days now (yeah, in San Diego, go figure). Tonight on my way home I got the error on the MFD for the adaptive light. When I got home, the left light was pointing left and I could hear the motor trying to adjust it (back to center I guess). It would not budge so I turned off the car and went inside to have dinner. I then fired up the trusty VAGCOM and scanned to see what the issue was. The result is pasted below. I ran all the tests and it all worked perfect, the lamp went back to normal and all functions are OK. I did reset the DTC, all seems to be working.
I am thinking maybe there is some water leaking into the harness, but I was not able to see much. I will take a look again tomorrow. Looks like the sensor malfunctioned. Any previous experience or comments will be appreciated.
Cheers.
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
Shop #: WSC 02313 785 00200
VCID: 2952E6F5F98B
Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Component: AFS-Modul rechtsH01 0010
1 Fault Found:
02629 - Sensor for Swivel Module Position; Left
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00111000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 29224 km
Time Indication: 0
Date: 2010.10.19
Time: 19:39:42
Cheers.
Coding: 0000018
VCID: 2952E6F5F98B
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 29224 km
Time Indication: 0
Date: 2010.10.19
Time: 19:39:42
So basically it just fixed itself? Thank god for you
I'm sure it was maybe just condensation messing with it. Half the errors you get with these machines fix themselves. Heres a few good examples I've had
Passenger side window wouldn't roll up, only down. Fixed itself after 10 minutes, never happened again
Master window switch that controls the passenger side window the roll up function was intermittent. Works perfect now after 1 month of issues.
TPMS gets a malfunction every once in a while, I just initialize the wheels and it resets and works perfect.
Whoa! Just took a look at it, there is a hole on the back of the module (the one that sits behind the lamp, not on the side) about 1/4" big. Must have happened with the accident. All is working now, so I took a blow drier to make sure all is dry and put a bit of silicone on it. I guess some moisture from the rain must have gotten in there. Hope it works.
Cheers.
Cheers.
Cheers.
Cheers.
Raining like hell in Las Vegas too. Palm Springs was hot and sunny last week for me.
awdinut
01-12-2018 12:51 PM
CoOlSlY
17
01-30-2004 11:43 AM
