Adaptive Lighting and Xenon Range Error
I have a problem with headlight range system and adaptive lighting on my 2004 A8L. I read other similar posts, but my symptoms seem to be a bit different, and I can't find any conclusive fix for the problem on the forum. In the meantime I have removed the 10amp fuse #4 as others suggested, and that has eliminated the dashboard error and the display is back to normal. I would still like to address the problem, but I'm not sure what the actual problem part is, given the error codes.
Here is what VCDS sees:
VCDS
Windows Based VAG/VAS Emulator
VCDS Version: Release 11.11.2 Data version: 20120126
www.Ross-Tech.com
Dealer/Shop Name:
Workshop Code: 000 00000
Self-Diagnosis Log
Tuesday,31,January,2012,14:52:35:11261
License Plate: 11
Mileage: 152700km-94883mi Repair Order: 1
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 72 75 76
Mileage: 152700km/94883miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: OK 0000
76-Park Assist -- Status: OK 0000
VCDS
Self-Diagnosis Log
License Plate: 11
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0D2536917
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F46EAA8CEA6FDB
No fault code found.
Readiness: 0110 1101
VCDS
Self-Diagnosis Log
Tuesday,31,January,2012,14:52:37:11261
License Plate: 11
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 J HW: 4E0 907 279 J
Component: ILM Fahrer H12 0190
Coding: 0113113
VCID: 2F661A68BE066DB
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0030
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 152700 km
Time Indication: 0
Date: 2012.01.31
Time: 14:10:03
VCDS
Self-Diagnosis Log
Page 6
License Plate: 11
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
Shop #: WSC 05927 444 59322
VCID: 254AF840ECFA27B
1 Fault Found:
01575 - Control Switched Off
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 152700 km
Time Indication: 0
Date: 2012.01.31
Time: 14:46:16
VCDS
Self-Diagnosis Log
Page 9
License Plate: 11
Address 55: Xenon Range Labels: None
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 02311 785 00200
VCID: E2C0235C3D54103
2 Faults Found:
01539 - Headlights Not Adjusted
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 152696 km
Time Indication: 0
Date: 2012.01.31
Time: 14:47:31
02234 - Right Headlight Power Output Stage (J668)
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 152696 km
Time Indication: 0
Date: 2012.01.31
Time: 14:47:32
I read in the Bently program that there are two TSBs related to this problem, but I am new to Audi, and I'm not sure how to interpret the TSB (including how to reference the TSB number). I think it is called 94 09 16 from June 17th, 2009. The other is 94-08-20 from Nov 6th, 2008. The former seems to reference the part number 4E0 907 357, which VAG calls "HW", I assume meaning hardware? The TSB acually says 4F0 907 357 as the part number. I think it might be a typo. If this is the problem, the TSB indicates that it cannot be updated, and must be replaced.
I am not covered by a warranty. I wouldn't think Audi will still do anything for this, right?
Where should I start without just replacing everything? Any experience is greatly appreciated.
VCDS
www.Ross-Tech.com
Dealer/Shop Name:
Self-Diagnosis Log
License Plate: 11
Chassis Type: 4E0
VCDS
Self-Diagnosis Log
License Plate: 11
Coding: 0007773
VCDS
Self-Diagnosis Log
License Plate: 11
Coding: 0113113
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 152700 km
Time Indication: 0
Date: 2012.01.31
Time: 14:10:03
VCDS
Self-Diagnosis Log
Page 6
License Plate: 11
Coding: 0015510
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 22
Mileage: 152700 km
Time Indication: 0
Date: 2012.01.31
Time: 14:46:16
VCDS
Self-Diagnosis Log
Page 9
License Plate: 11
Coding: 0000004
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 152696 km
Time Indication: 0
Date: 2012.01.31
Time: 14:47:31
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 22
Mileage: 152696 km
Time Indication: 0
Date: 2012.01.31
Time: 14:47:32
That is the scan with the fuse in place. With the fuse removed you get about 12-15 error blocks. So, it looks like the problem might be in the level controller? I also nticed that the wiring in the headlights is deteriorating. Is this a common problem, and is there a fix other than replacing the headlight assembly?
Hey buddy, not sure if this is of any use, but one of the guys just told me how to recode the 55-address controller (xenons). Not sure if you've tried that, but I had to do it after I replaced low beam bulbs. Check my posts towards the end of 'D3 headlight exploded diagram' thread, one of the guys there (sorry, can't remember his user name, but on here a lot) gives a method for recoding under VagCom that, combined with clearing DTC's, removed my dashboard error message.
Good luck,![Wink](https://www.audiworld.com/forums/images/smilies/wink.gif)
K9
Good luck,
K9
Teknic
04-19-2006 06:44 PM
