Air suspension pump won't stop running
So after i turn off my car the air pump keeps going and i saw some smoke coming from it so i disconnected the battery and it seems the relay is broken from internet research, my question is: where is the relay for the air compressor?
You need to use a Hard Plastic Trim Removal Tool to pull off the Long Trim Piece that runs below the Dash Wood Trim. It is the Peace that is just below the Coin Tray. Remove the Coin Tray first before removing the Trim, but go Easy and be Gentle. Remove the Driver's Side Fuse Panel Cover and you will see 2 or 3 Screws to remove. There is 1 Screw next to the Steering Column behind the Trim Piece that you removed. The other 2 or 3 Screws are just beneath the Driver's Knee Panel. Once you remove the Panel you will see 3or 4 Relays in a Row left to right if I remember correctly it is the 1st Relay. Before you can pull the Relay out you have to remove the Bracket that is Blocking the Relays and you're set. Call your Audi Parts Dept and get the OEM Part# and Google it. You will Find OEM and OE Relays. They're not that Expensive, but I would stay away from the Super Cheap Relays as they are not OEM or OE Parts. Good luck and pray that you haven't overheated the Compressor. Laters,
The coin tray bezel slides to the left for removal. Do it carefully as replacement cost is about $35. Here is the picture of it removed. The bezel has two posts that slide into the keeper, and break very easily.
http://picasaweb.google.com/lh/photo...vp7Q34VMYrhQv0
Agreed, g*e*n*t*l*y slide to the left!
This should help you pinpoint problems as well with Air Suspension.
www.volkspage.net/technik/ssp/ssp/SSP_292.pdf
I'm having the same problem now and I'm about to order a new compressor. Before I do that, I want to know if it's the relay which is causing the problem? This would save me a ton of money. Thanks.
By the way, are you from Hawaii?
