Airbag Light code 00591 - Seat Belt Switch; Driver (E24)
So my airbag light has came on. It stayed on for a bit and then went away but it has returned. I scanned it with my Vag-Com and got this code. This is on a 2008 A8L. I assume that a wiring connection between the seat belt and the system has a fault in it. Any ideas on how to fix it?
Address 15: Airbags Labels: None
Control Module Part Number: 4E0 910 655 F HW: 4E0 959 655 L
Component and/or Version: Airbag 9.41 H01 4230
Software Coding: 0532707
Work Shop Code: WSC 02313 785 00200
Additional Info: 4E0910339C BF-Gewichtsens. H02 0040
Additional Info: Geraet 00200
VCID: 290CF45CF5F9FE7F5A7-807C
1 Fault Found:
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 16
Reset counter: 112
Mileage: 174002 km
Time Indication: 0
Date: 2017.06.16
Time: 17:33:21
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 16
Reset counter: 112
Mileage: 174002 km
Time Indication: 0
Date: 2017.06.16
Time: 17:33:21
Could be just as easily the sensor in the buckle as well. Repair means first inspect wiring and connector, and if no fault can be found, replace the suspect part. I would guess the buckle and switch are a single unit to replace, but I could be wrong.
PKmode
12-28-2007 12:52 PM
SharkAttack (4.2go)
07-23-2006 10:07 AM
