Anyone ever replace MMI interface?
#21
Dealer connected VCDS and told me, "multiple control units faulty. CD changer, front display control unit, sound system amplifier, radio and telephone control unit." They recommend replace all the units at a cost of $7K.
Everything worked perfectly, then bluetooth began acting up. Searched forums and found others with bluetooth issues had success by updating to version 4610. When I updated, it hung up mid way through and since then nothing works. Searching here and saw Williebone thread about replacing MMI 07 Control Head. Said he can provide with Component Protection disabled... "plug and play"... Sounded like a good place to start.
What do you think?
I'm going to buy my ownVCDS. Any recommendation on what and where to get?
Thanks!!
What do you think?
Thanks!!
Cheers,
Louis
#22
What do you think?
Thanks!!
What do you think?
Thanks!!
As Louis stated, get the optical loop tester, and as you stated that the BT started acting up first, I would lift the carpet on the front drivers side to expose the BT module and look for signs of wetness, and at the same time installing the optic loop bypass on said fiber optic connection at BT module.
Also fill in your location, or tell us where you are located so someone may be willing to help you.
And I would love to hear what you said to the dealer in response to his/her statement of "multiple control units faulty. CD changer, front display control unit, sound system amplifier, radio and telephone control unit." and " recommend replace all the units at a cost of $7K.".....
#23
What do you think?
Thanks!!
What do you think?
Thanks!!
#24
What do you think?
Thanks!!
What do you think?
Thanks!!
Hello Scott,
Filled in my location and would greatly appreciate anyone near Denver / Boulder CO who can offer assistance.
I've ordered the Optical loop and will let you know what I find when I pull up the carpet.
Thanks!
#26
Julian
Sample below from my UK car
Code:
Thursday,17,August,2017,14:03:41:53697 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 17.8.0.1 Data version: 20170721 DS276.2 Ross-Tech: Home Dealer/Shop Name: VAG.Scans VIN: WAUZZZ4E35N011492 License Plate: Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 18 19 1D 1E 25 34 36 37 38 42 46 47 4F 52 53 56 57 61 62 72 76 77 VIN: WAUZZZ4E35N011492 Mileage: 370660km-230317miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 18-Aux. Heat -- Status: Malfunction 0010 19-CAN Gateway -- Status: OK 0000 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 059-907-401-ASB.clb Part No SW: 4E0 910 401 J HW: 4E0 907 401 B Component: 3.0L V6TDI G000AG 0020 Revision: --H01--- Serial number: AUX3Z0D9353518 Coding: 0011973 Shop #: WSC 02313 785 00200 VCID: 224B8DE9FD1E3056BC-8076 3 Faults Found: 17983 - Right Engine Mount Solenoid Valve (N145) P1575 - 001 - Short to Plus Freeze Frame: RPM: 777 /min Torque: 70.2 Nm Speed: 0.0 km/h Voltage: 13.15 V Bin. Bits: 0 Bin. Bits: 0 Bin. Bits: 0 Temperature: 44.1°C 18281 - Transmission Mount Valve 2 (N263) P1873 - 001 - Open Circuit Freeze Frame: RPM: 777 /min Torque: 70.2 Nm Speed: 0.0 km/h Voltage: 13.15 V Bin. Bits: 0 Bin. Bits: 0 Bin. Bits: 0 Temperature: 44.1°C 18276 - Transmission Mount Valve 1 (N262) P1868 - 001 - Short to Plus Freeze Frame: RPM: 777 /min Torque: 70.2 Nm Speed: 0.0 km/h Duty Cycle: 1.0 % Voltage: 13.15 V Bin. Bits: 00101100 Torque: 195.0 Nm Temperature: 44.1°C Readiness: 0 0 1 1 1 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4E0 910 156 F HW: 09L 927 156 Component: AG6 09L 3.0lTDI RdW 0070 Revision: --H01--- Serial number: 0070658 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 254196F5EC30C76ED9-8070 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0008357 Shop #: WSC 02313 000 00000 VCID: 224B8DE9FD1E3056BC-8076 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 C Component: FBS AUDID3 H04 0140 Revision: 01404004 Serial number: AUX3Z0D9353518 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BFEF01EBC2AA8692-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H08 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 3670112 Shop #: WSC 02313 785 00200 VCID: 234588EDE204395EB7-8076 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300KS047541498 Coding: 0000002 Shop #: WSC 00045 210 90242 VCID: 3A7B5589758E589684-806E Subsystem 1 - Part No: 4E0 910 609 A Component: Bedienteil MMI H42 0020 Subsystem 2 - Serial number: 318IE047510004 Subsystem 3 - Serial number: 7409.09.0400000000218B0053˙ Subsystem 4 - Serial number: 8B0053˙ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: User\4E0-910-043.lbl Part No SW: 4E0 910 043 A HW: 4E0 820 043 A Component: KLIMAAUTOMAT 016 0340 Revision: 00000029 Serial number: 00000000057290 Coding: 1067041 Shop #: WSC 02311 785 00200 VCID: 1B35B00DDA74019E7F-804E No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 L HW: 4E0 907 279 L Component: ILM Fahrer H12 0210 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 316972A5A8F89BCE35-8064 Subsystem 1 - Part No: 4E2 910 113 B Component: Wischer WWS D3 H50 0420 Coding: 00000037 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBD6029817 Shop #: WSC 00000 000 00000 VCID: 1C37B311DF7A06A676-8048 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 G Component: Airbag 8.4E+ H10 0940 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 63C5C8EDA284795EF7-8036 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0112141 Shop #: WSC 02311 785 00200 VCID: 65C1D6F5ACB0076E19-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H04 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: User\4E0-910-xxx-17.lbl Part No SW: 4E0 910 950 F HW: 4E0 920 950 F Component: KOMBIINSTR. VDO H49 0200 Revision: D03 Serial number: AUDID3DN000886 Coding: 0000418 Shop #: WSC 00028 210 01865 VCID: 275D9CFD963CD57EEB-8072 No fault code found. ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 A HW: 4E0 815 069 E Component: Heizgeraet H07 0100 Revision: 0000000B Serial number: 00000009006406 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 1A3BB509D54E789664-804E 2 Faults Found: 01406 - No Flame 000 - - 02251 - Heater Unit Locked 000 - - ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4E0-910-468.clb Part No SW: 4E0 910 468 HW: 4E0 907 468 A Component: Gateway H07 0070 Revision: 07 Serial number: 160030482517A7 Coding: FCFF5BDE3B3504 Shop #: WSC 02313 785 00200 VCID: 65C1D6F5ACB0076E19-8030 No fault code found. ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl Part No SW: 4E0 910 218 HW: 4E2 905 218 Component: FPI_1 H07 0060 Revision: 06000107 Serial number: 23092004154705 Shop #: WSC 00000 000 00000 VCID: 5EB3F91989E654B6D8-800A No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl Part No SW: 4E0 035 785 F HW: 4E0 035 785 C Component: SG ext.Player H20 0850 Revision: 00000000 Coding: 010000 Shop #: WSC 00000 000 00000 VCID: 2B5560CD4AD4F11E0F-807E No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 C Component: FBS AUDID3 H04 0140 Revision: 01404004 Serial number: AUX3Z0D9353518 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58BFEF01EBC2AA8692-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 34: Level Control Labels: User\4E0-910-553.lbl Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0015510 Shop #: WSC 02313 785 00200 VCID: 285F9FC19B22DA06E2-807C No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory FS H08 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 3670126 Shop #: WSC 02313 785 00200 VCID: 234588EDE204395EB7-8076 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 C Component: MNS ECE H43 1060 Revision: 00000000 Serial number: 353K0047589079 Shop #: WSC 02313 785 00200 VCID: 3B75508D7AB4619E9F-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H02 0090 Serial number: 00000430200115 Coding: 0035904 Shop #: WSC 02313 785 00200 VCID: 1D31BE15C4600FAE81-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 B Component: Türsteuer.FS BRM002 0060 Coding: 0026914 Shop #: WSC 02311 785 00200 VCID: 204F87E1F3122246AA-8074 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H04 0040 Revision: 00400004 Serial number: W040411110043 Coding: 0000249 Shop #: WSC 02313 785 00200 VCID: 275D9CFD963CD57EEB-8072 Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel P14H06 0070 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H03 0020 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 P HW: 4E0 035 223 A Component: DSP-Amp.-High H13 0460 Revision: PROD_01 Serial number: 00000000008586 Coding: 0000013 Shop #: WSC 02313 785 00200 VCID: 2A5B65C9852EE816F4-807E No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H09 0040 Revision: Serial number: 00000000051553 Coding: 0010001 Shop #: WSC 02313 785 00200 VCID: 1E33B919C96614B698-804A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 B Component: Türsteuer.BF BRM002 0060 Coding: 0026914 Shop #: WSC 02311 785 00200 VCID: 204F87E1F3122246AA-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 A HW: 4E0 907 801 Component: EPB AV1C1010 H01 1010 Revision: AV1C1010 Coding: 0000221 Shop #: WSC 00011 210 01865 VCID: 1D31BE15C4600FAE81-8048 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 B Component: TUNER EU/US/RDW H41 0630 Revision: 00000000 Serial number: 304KJ047604701 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 316972A5A8F89BCE35-8064 No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: 4E0-910-146.clb Part No SW: 4E0 910 146 G HW: 4E0 919 146 A Component: TV analog TUNER H13 0300 Revision: 00000024 Serial number: 00000000008454 Coding: 0000003 Shop #: WSC 02313 785 00200 VCID: 254196F5EC30C76ED9-8070 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: User\4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H11 0510 Revision: 00000000 Serial number: 00000000014066 Shop #: WSC 00028 210 01865 VCID: 204F87E1F3122246AA-8074 Subsystem 1 - Part No: 000 915 105 DL Component: von VA0 331029T03K Coding: 303030393135313035444C5641303333313032395430334B Shop #: WSC 00011 888 06946 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: Türsteuer.HL BRM002 0060 Coding: 0026914 Shop #: WSC 02311 785 00200 VCID: 1E33B919C96614B698-804A No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: Türsteuer.HR BRM002 0060 Coding: 0026914 Shop #: WSC 02311 785 00200 VCID: 1E33B919C96614B698-804A No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0030 Revision: 00H12000 Serial number: 08720610203793 Coding: 0301008 Shop #: WSC 02313 785 00200 VCID: 234588EDE204395EB7-8076 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-333.lbl Part No SW: 4E0 910 333 F HW: 4E0 862 333 B Component: TELEFONMODUL EU 0770 Revision: 00000001 Serial number: 00000000000000 Coding: 0000004 Shop #: WSC 02313 785 00200 VCID: 224B8DE9FD1E3056BC-8076 No fault code found. End-------------------------(Elapsed Time: 03:47)--------------------------
#29
It obviously still worked as you were able to try and run the software update!
And what happened when you tried to update the software with the CDs that made it subsequently 'bricked'?
Julian
BTW, you might like to retry running the swupdate as sometimes that fixes it!
Last edited by JulianHicks; 12-27-2017 at 10:43 AM. Reason: Add update comment ...
#30
Hi Scott; while you wait would you like to say a bit more about how the MMI 'acted funny'?
Julian
Julian
This is the chronology with my MMI:
- Bluetooth connection to my phone stopped working. Every 20 seconds the radio would cut out for 5 seconds. MMI was trying to connect bluetooth
- Ran 4610 update CD #1 and it hung up in a never ending loop. "flashing drive" "0% progress"... repeat. "flashing drive" "0% progress"... repeat.
- Canceled update in spite of warning "May damage your system". I had no choice. It was doing the same thing for hours.
Kept trying the update with same result. But now my MMI ran very slow. Screens loading VERY slowly... none of the sources work, i.e. radio, CD, etc.)
- Kept tinkering with it and some how it popped into bootloader. I did not make it happen as my hidden green menu is not enabled. I think the system just puked and went to bootloader.
- The #1 CD was in and it said it was updating to 4610. After reboot, success! I thought I was out of the woods because it now said version was 4610.
MMI operating system was back up to full speed, screens all loaded quickly. But... still none of the sources would work. So tried the software update again (thinking perhaps the MMI main unit updated but not the other devices)
- No good. Still would not run the update and back to crippled operating system. Screens load but very slowly. It reboots constantly.
I took it to the dealer to get them to enable the green screen so I could run bootloader again and try reinstalling the software. Could not believe my ears when the shop manager told me "never heard of it"
They spent all of 10 minutes on trying and gave up.
Here's where I think I am (emphasis on "think") I have a hardware problem, probably the bluetooth, plus a software problem due to the failed 4610 update. When I get VCDS and optical loops I plan to enable the green screen, enable and run bootloader to try and get my main unit back on it's feet. Then I will see what VCDS says and rebuild from there.
Any thoughts? I've found very little commentary on using the bootloader and would love to hear from someone with that has experience with it.
Thanks!
