Audi a8
Hello guys! I have an Audi a8 d3 2007 ! Can anyone help me with a wire diagram for air con presure sensor! Does anyone know from where to take a wire with signal for ac presure sensor? Mine doesn't have signal! Thanks
Not sure why you want this information. I believe it is all logic level signals.
Use VAG-Com software to troubleshoot.
You need to pull a vacuum and then the refrigerant will quickly enter the system and cause the switch to activate the valves in the compressor cauzing the prescribed amont of refriverant to fill thr circuit.
This assumes you use a specific measurement of refrigerant.
You need the service manual for the vehicle.
Read this thread or this post.
Read them well and don't guess or short cut steps, find the real culprit, it's a complex system.
Cheers,
Louis
Cheers,
Louis
Cheers,
Louis
Cheers,
Louis
I've got the same fault code - "00819 Open or Short to Plus." I think this might be a connector issue. This looks different from the other 00819 fault codes. Maybe a broken wire somewhere? I've got a new G65 sensor on the way, the Hella sensor I have might be bad. When I installed the Hella sensor the fans run whenever the engines runs, even if I turn the A/C off.
Originally Posted by Cońdrache Costel
I read them! But I tried also and nothing! When I do a test to my ac compressor with Vcds is working! Il try this week to change the climate control to see if there could be a problem!
Louis, you think an open short to plus error will also be fixed with proper refrigeration and correct install of G65, even though you were seeing a different 00819 code.?
