Audi D3 Aux Setup
is there anyway I can set up an Auxiliary in my car ? I have a 2006 A8L and i dont have any Aux input and this sucks... from what I been reading i have no interface in my glove box... I herd of the dension equipment but can I just cut a wire or 2 and hook up my own aux ?
My MMI is currently on 6346 11.9.0. 0513
I plan on doing this:
I have a factory TV module, with 2 AV inputs.
So the first part will be the TV plug pins to RCA
![](http://galleryplus.ebayimg.com/ws/web/351194176360_1_0_1/1000x1000.jpg)
Then the Bluetooth streaming thing:
![](http://www.greatlakesscuttlebutt.com/clientuploads/news/July%202013/bluetooth.jpg)
And that should be a cheap and easy way to enable Bluetooth streaming in the MMI.
Start here: https://www.audiworld.com/forums/a8-...-read-2877219/
There really are several threads in the forums on how to do this, everything from very basic, to full blown apple and android solutions, I have found most of the good information in the C6 forums.
I went with adding an AMI, and then tune2air. I have done this in both of my cars, and my wife's current one. It is a pretty solid way to go. and not too expensive.
If you do not have an AMI, find one, Ebay, UpullUPay, what ever. They are fairly common. I thought I had an extra one, but can not seem to find it. Anyway, Next, update your MMI software, Lots of threads on this also.
You can get the files here
https://drive.google.com/drive/folde...lL?usp=sharing
you may need to upgrade the firmware of the AMI as well. You will need
1 Bovee 1000 or Bovee WMA3000A if you get the 1000, you will also need the interface cable.
1 and I got just because, who knows.
Hope this helps a bit.
AudiWorld Wiseguy
Anyway, AUX input is the yesterdecade solution so don’t bother. Apple CarPlay/Android Auto is where it’s at today and there is an excellent plug and play solution that many of us have already installed. www.mr12volt.com
Sinful_A3
06-14-2005 08:03 AM
Sinful_A3
06-13-2005 09:10 PM
