Audi S8 2013 , EPC light always on, no power, rough idling after it gets warm
Hello everyone, i have S8 2013 with EPC light always on, no power rough idling engine after it get warm , please Help 🥲💔thia is the OBDeleven data log Date: 2023-03-17 06:51 VIN: WAUA2BFD3DN008278 Car: Audi S8 Year: 2013 Body type: Saloon Engine: CGTA Mileage: 134007 KM ---------------------------------------------------------------01 Engine System description: 4.0l V8TFSI / Software number: 4H0907557 Software version: 0010 Hardware number: 4H0906014 Hardware version: H56 ODX name: EV_ECM40TFS0114H0907557 ODX version: 001012 Long coding: 022A00326526010A1000 Trouble codes: P023B00 - Charge Air Cooler Coolant Pump Control Circuit Low static P059800 - Thermostat Heater Control Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P187200 - Right Transmission Mount Valve Short circuit to ground static P186900 - Left Transmission Mount Valve Short circuit to ground static P261A00 - Coolant Pump "B" Control Circuit/Open static P199D00 - Cylinder head coolant valve Short circuit to ground static P165F00 - Oil pressure regulation valve Short circuit to ground static P25AA00 - Piston Cooling Oil Control Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31A500 - Cam Shift Actuator "B" Cylinder 5 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31A800 - Cam Shift Actuator "B" Cylinder 8 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31A300 - Cam Shift Actuator "B" Cylinder 3 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31A200 - Cam Shift Actuator "B" Cylinder 2 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31AD00 - Cam Shift Actuator Outlet "B" Cylinder 5 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31B000 - Cam Shift Actuator Outlet "B" Cylinder 8 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31AB00 - Cam Shift Actuator Outlet "B" Cylinder 3 Circuit Low static Date: 2023-03-07 10:48:58 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31AA00 - Cam Shift Actuator Outlet "B" Cylinder 2 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31B500 - Cam Shift Actuator "A" Cylinder 5 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31B800 - Cam Shift Actuator "A" Cylinder 8 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31B300 - Cam Shift Actuator "A" Cylinder 3 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31B200 - Cam Shift Actuator "A" Cylinder 2 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31BD00 - Cam Shift Actuator Outlet "A" Cylinder 5 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31C000 - Cam Shift Actuator Outlet "A" Cylinder 8 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31BB00 - Cam Shift Actuator Outlet "A" Cylinder 3 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P31BA00 - Cam Shift Actuator Outlet "A" Cylinder 2 Circuit Low static Date: 2023-03-07 10:48:59 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 0.00 1/min Normed load value: 0.0 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 35 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 12.133 V Dynamic environmental data: 20962810160000128C0000000013380512160BA8129D5B11D9 329D10100000 P200900 - Intake Manifold Runner Bank 1 Control Circuit Low static Date: 2023-03-07 10:49:12 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 210.50 1/min Normed load value: 25.1 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 36 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 10.719 V Dynamic environmental data: 20962810160199128C0000085113380512160A89129D5B11D9 2D0B10100140 P143500 - Secondary air injection pump relay Short circuit to ground static P041700 - Sec.Air Inj.Sys.Switching Valve B Circ. Shorted static Date: 2023-03-07 10:49:12 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Engine speed: 210.50 1/min Normed load value: 25.1 % Vehicle speed: 0 km/h Coolant temperature: 62 °C Intake air temperature: 36 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 10.719 V Dynamic environmental data: 20962810160199128C0000085D13380512160A89129D5B11D9 2D0B10100140 P142100 - Secondary air injection Solen.val. Short circuit to ground static P045800 - EVAP System Purge Control Valve "A" Circuit Low static P00C100 - Turbocharger/Supercharger Bypass Valve "B" Control Circuit Low static P003400 - Turbo Charger Bypass Valve Control Circuit Low static ---------------------------------------------------------------02 Transmission System description: 0BK 40TFSIUSA Software number: 4H1927158EG Software version: 1002 Hardware number: 0BK927156AG Hardware version: H16 ODX name: EV_TCMALX51011 ODX version: 002022 Long coding: 000001 Trouble codes: P275300 - Transmission Fluid Cooler Control Circuit/Open static Date: 2023-03-07 10:49:03 Mileage: 134007 km Priority: 2 Malfunction frequency counter: 1 Unlearning counter: 255 Dynamic environmental data: 209628F4422F80212F2F741024000010250000102600001027 00001028000010290000102A000010370000F40C000021044A 030149210F02102D801E103401E2103BFF ---------------------------------------------------------------03 Brakes System description: ESP PREMIUM Software number: 4H0907379D Software version: 0352 Hardware number: 4H0907379D Hardware version: H10 Serial number: -------------- ODX name: EV_ESPPremi ODX version: 005013 Long coding: C2FDA30043BFC500E300 Trouble codes: No trouble codes found ---------------------------------------------------------------04 Steering Angle Sensor Trouble codes: No trouble codes found ---------------------------------------------------------------05 Keyless System System description: BCM2 2.0 Software number: 4H0907064DF Software version: 0510 Hardware number: 4H0907064CF Hardware version: H32 Long coding: 05A72F46000000000000 Trouble codes: No trouble codes found ---------------------------------------------------------------06 Passenger Seat System description: MEM-BFS Software number: 4H0959760E Software version: 0153 Hardware number: 4H0959760E Hardware version: H08 Serial number: 00000033624083 Long coding: C018320085047201000001010101112131313333283333 Trouble codes: No trouble codes found ---------------------------------------------------------------08 Air Conditioning System description: Klima 4 Zonen Software number: 4H0820043H Software version: 0120 Hardware number: 4H0820043H Hardware version: H20 ODX name: EV_AirCondiFront ODX version: 001050 Long coding: 6801207838 Trouble codes: B10BA22 - Right footwell flap motor Upper limit exceeded static ---------------------------------------------------------------09 Central Electrics System description: BCM1 2.0 Software number: 4H0907063CG Software version: 0130 Hardware number: 4H0907063 Hardware version: H12 Serial number: 00000001369213 Long coding: 0907201009749FF1BB810044A0001800009CC3080E00010180 0108546F01 Subsystems: System description: WWS641 120419 Software number: 4H1955119C Software version: 0080 Hardware version: H35 Serial number: 120618081654 Long coding: 0045F7 System description: RLS Software number: 8K0955559C Software version: 0003 Hardware version: H04 Serial number: 10266705 Long coding: 025523 System description: E1 - LDS Software number: 4H0941531B Software version: 0044 Hardware version: H07 Serial number: 09 07 2012 00000766 System description: A31 LED Mod1L Software number: 4H0907472B Software version: 0006 Hardware version: H03 Serial number: 00000005071200010455 Long coding: 100000 System description: A27 LED Mod1R Software number: 4H0907472B Software version: 0006 Hardware version: H03 Serial number: 00000005071200010066 Long coding: 100000 System description: EVLS-SG Software number: 4H0907705K Software version: 0300 Hardware version: H08 Serial number: WA103815000001527867 Long coding: 020300 System description: AQ_Hum_Sensor Software number: 4H0907658 Software version: 0003 Hardware version: H03 Serial number: 2A788736000000000001 Trouble codes: No trouble codes found ---------------------------------------------------------------0E Media Player System description: DVDCAlpine Software number: 4H0035108F Software version: 0200 Hardware number: 4H0035108 Hardware version: H42 Long coding: 010000 Trouble codes: No trouble codes found ---------------------------------------------------------------10 Parking Assistance System description: PARKHILFE ACC Software number: 4H0919475AG Software version: 0072 Hardware number: 4H0919475AG Hardware version: H01 Serial number: 61061219100374 ODX name: EV_EPHVA18AU57X0000 ODX version: 003008 Long coding: 280301 Trouble codes: No trouble codes found ---------------------------------------------------------------15 Airbag System description: Airbag10.43 Software number: 4H0959655C Software version: 0040 Hardware number: 4H0959655C Hardware version: H43 Serial number: 003JG009DN52 ODX name: EV_AirbaAU10BPAAU64X ODX version: 001014 Long coding: 30314246323430303034554A304C34483053 Trouble codes: No trouble codes found ---------------------------------------------------------------16 Steering Column System description: Lenks.Modul Software number: 4H0953568G Software version: 0005 Hardware number: 4H0953568G Hardware version: H03 Serial number: 90815LG90003W Long coding: 000034 Subsystems: System description: E221 - MFL Software number: 4H0951528A Software version: 0009 Hardware version: H08 Serial number: 09 05 2012 D0065506 Trouble codes: No trouble codes found ---------------------------------------------------------------17 Dashboard System description: TBenRDW---NV- Software number: 4H0920800Q Software version: 0515 Hardware number: 4H0920800Q Hardware version: H72 Serial number: 6580207125920451 ODX name: EV_RBD4K ODX version: 004046 Long coding: 53A70802B3400008010100 Subsystems: System description: Analoguhr D4 Software number: 4H0919204K Software version: 0224 Hardware version: H05 Serial number: 1120622000528 Trouble codes: No trouble codes found ---------------------------------------------------------------19 Gateway System description: J533--Gateway Software number: 4H0907468AB Software version: 0028 Hardware number: 4H0907468AA Hardware version: H10 Serial number: 00000000588034 ODX name: EV_GatewPkoUDS ODX version: 001013 Long coding: 00ED074800 Subsystems: System description: J367-BDM Software number: 4H0915181F Software version: 0181 Hardware version: H08 Serial number: 00000000004970677056 Trouble codes: U104500 - Lane change assistance control module No communication static U005400 - Vehicle Communication Bus C (-) shorted to Bus C (+) Intermittent ---------------------------------------------------------------1B Active Steering System description: DYNAMIKLENK. Software number: 4H0907144C Software version: 0100 Hardware number: 4H0907144C Hardware version: H06 Serial number: -------------- Long coding: 090100 Trouble codes: No trouble codes found ---------------------------------------------------------------20 High Beam Assistance System description: FLA Software number: 8K0857511F Software version: 0020 Hardware number: 8K0857511A Hardware version: H04 Long coding: 04018B6B74745D545420363E00 Trouble codes: No trouble codes found ---------------------------------------------------------------22 All Wheel Control System description: 4 Wheel Drive Software number: 4H0907163A Software version: 0013 Hardware number: 4H0907163A Hardware version: H15 Serial number: 0022061200010751 ODX name: EV_AllWheelDiffeQSPFR ODX version: 003023 Trouble codes: No trouble codes found ---------------------------------------------------------------28 Rear Climate Control System description: Klima Fond Software number: 4H0919158C Software version: 0120 Hardware number: 4H0919158C Hardware version: H16 ODX name: EV_AirCondiHeck ODX version: 001039 Long coding: 2000000000 Trouble codes: No trouble codes found ---------------------------------------------------------------34 Chassis Control System description: LUFE-DAEMPFER Software number: 4H0907553E Software version: 0099 Hardware number: 4H0907553 Hardware version: H17 Serial number: ‡0 a ODX name: EV_AirSuspe ODX version: 003024 Long coding: 008004 Trouble codes: No trouble codes found ---------------------------------------------------------------36 Driver Seat System description: MEM-FS Software number: 4H0959760E Software version: 0153 Hardware number: 4H0959760E Hardware version: H08 Serial number: 00000033624057 Long coding: C0183B0085057201000001010101112131313333203333 Trouble codes: No trouble codes found ---------------------------------------------------------------3B Sensor Electronics System description: SARA 6D red Software number: 4H0907637L Software version: 0053 Hardware number: 4H0907637G Hardware version: H02 Serial number: EJ1BPA710011SW ODX name: EV_SARA2 ODX version: 005011 Trouble codes: No trouble codes found ---------------------------------------------------------------3C Lane Change Assistant Right Trouble codes: No trouble codes found ---------------------------------------------------------------42 Driver Door System description: TSG FA Software number: 4H0959793R Software version: 0263 Hardware number: 4H0959793G Hardware version: H06 Serial number: 0000128767153 Long coding: 011F1E005E0062C202083016 Trouble codes: 02849 - Lane change assistance control module No signal/communication static Priority: 6 Frequency counter: 54 Driving cycle: 147 Mileage: 133971 km Date: 2022-12-26 22:13:30 ---------------------------------------------------------------46 Comfort System System description: BCM2 2.0 Software number: 4H0907064DF Software version: 0510 Hardware number: 4H0907064CF Hardware version: H32 Serial number: 0179834048 Long coding: 011A0E2000B93585B330C7C40A03010F000000000000000000 0000000000 Subsystems: System description: DWA-Sensor Software number: 4H0951177 Software version: 0010 Hardware version: H01 System description: LIN BACKUP HO Software number: 1K0951605C Software version: 1501 Hardware version: H05 System description: J245 PS50.030 Software number: 4H0959591 Software version: 0006 Hardware version: H07 Serial number: WOO16691221 Long coding: 901F00 System description: Dachelektroni Software number: 4H0947135G Software version: 0080 Hardware version: H11 Serial number: A2012000000000594553 Long coding: 010000 System description: V252 PS010 Software number: 4H0959591A Software version: 0005 Hardware version: H05 Serial number: WOO1000QQC$ System description: GEB.F.Heckoef Software number: 3AA962243 Software version: 0719 Hardware version: H12 Serial number: 84278361 Trouble codes: 00988 - Right brake light bulb Electrical error in circuit static Priority: 2 Frequency counter: 1 Driving cycle: 146 Mileage: 134007 km Date: 2023-02-18 10:43:34 01134 - Alarm horn Faulty static Priority: 2 Frequency counter: 1 Driving cycle: 146 Mileage: 134007 km Date: 2023-02-18 10:43:38 01504 - License plate lamp Electrical error in circuit Intermittent Priority: 2 Frequency counter: 1 Driving cycle: 187 Mileage: 134007 km Date: 2023-03-04 06:36:39 ---------------------------------------------------------------47 Sound System System description: BO G3 D4 ANC Software number: 4H1035465 Software version: 0130 Hardware number: 4H1035465 Hardware version: H03 Serial number: 0010600 Long coding: 020101 Subsystems: System description: BO D4 SLAVE Software number: 4H0035466 Software version: 0180 Hardware version: H51 Serial number: 02304120020189 Trouble codes: 03995 - Noise reduction conditions not fulfilled static Priority: 4 Frequency counter: 38 Driving cycle: 147 Date: 2022-12-26 22:13:37 03405 - Bass speaker Open circuit static Priority: 4 Frequency counter: 1 Driving cycle: 141 ---------------------------------------------------------------52 Passenger Door System description: TSG BF Software number: 4H0959792G Software version: 0261 Hardware number: 4H0959792G Hardware version: H06 Serial number: 0000129024622 Long coding: 011F1E005E0062C202083006 Trouble codes: No trouble codes found ---------------------------------------------------------------53 Parking Brake System description: EPB-4 Software number: 4H0907801F Software version: 0013 Hardware number: 4H0907801A Hardware version: H03 Serial number: 00000000403643 ODX name: EV_ParkiBrake ODX version: 001027 Trouble codes: No trouble codes found ---------------------------------------------------------------56 Radio System description: Radio U Basic Software number: 4H0035053G Software version: 0121 Hardware number: 4H0035053 Hardware version: H60 Serial number: 228G-0C7512554 Long coding: 070003010000000001 Trouble codes: 02983 - Connection between impedance converter 1 and window antenna Open circuit static Priority: 5 Frequency counter: 1 Driving cycle: 140 Mileage: 133971 km Date: 2022-12-26 22:13:45 02984 - Connection between impedance converter 2 and window antenna Open circuit static Priority: 5 Frequency counter: 1 Driving cycle: 140 Mileage: 133971 km Date: 2022-12-26 22:13:45 ---------------------------------------------------------------5F Multimedia System description: H-BNT-RW Software number: 4H0035764L Software version: 0637 Hardware number: 4H0035764N Hardware version: H44 Serial number: 181GU0C7501219 Long coding: 030D00000201F1EF55908B0E00000003740031020000000000 Subsystems: System description: ROW 2012 Software number: 8R0060884AJ Software version: 0403 System description: DU8 D4 SV NB Software number: 4H0919604F Software version: 0021 Hardware version: H47 Serial number: AUZ8ZDC9300NH5S System description: E380 BDT D4 Software number: 4H1919600H Software version: 0065 Hardware version: H09 Serial number: 00000000086626 System description: CD-Database Software number: 8R0060961C Software version: 3638 Trouble codes: 03157 - Function restriction due to communication interruption Intermittent Priority: 6 Frequency counter: 1 Driving cycle: 181 Mileage: 133971 km Date: 2022-12-26 22:14:24 03787 - Rotary mechanism for front display unit mechanical malfunction static Priority: 6 Frequency counter: 1 Driving cycle: 140 Mileage: 133971 km Date: 2022-12-26 22:14:21 ---------------------------------------------------------------62 Rear Left Door System description: TSG HL Software number: 4H0959795D Software version: 0262 Hardware number: 4H0959795D Hardware version: H06 Serial number: 0000129118799 Long coding: 010F1E00400062C202083006 Trouble codes: 02115 - Lock unit for central locking Implausible signal static Priority: 3 Frequency counter: 1 Driving cycle: 141 Mileage: 133971 km Date: 2022-12-26 22:27:11 01482 - Central locking motors Short circuit to B+ static Priority: 3 Frequency counter: 1 Driving cycle: 141 Mileage: 133971 km Date: 2022-12-26 22:27:11 01482 - Central locking motors Short circuit to ground static Priority: 3 Frequency counter: 1 Driving cycle: 141 Mileage: 133971 km Date: 2022-12-26 22:27:11 ---------------------------------------------------------------6C Rear View Camera System description: TopView Software number: 4H0907428A Software version: 0111 Hardware number: 7P6907441D Hardware version: H05 Serial number: 82330JF0046848 ODX name: EV_CamerSysteTopViewAUDI ODX version: 005022 Long coding: 0209000101010000000102000000 Trouble codes: No trouble codes found ---------------------------------------------------------------6D Deck Lid Control System description: HDSG-Modul Software number: 4H0959107R Software version: 0039 Hardware number: 4H0959107M Hardware version: H11 Serial number: 175200914 ODX name: EV_DeckLidContrUnit ODX version: 001025 Long coding: 0210044000 Trouble codes: No trouble codes found ---------------------------------------------------------------6F Comfort System 2 System description: ALM Software number: 4H0907412 Software version: 0004 Hardware number: 4H0907412 Hardware version: H05 Serial number: 000000079703 ODX name: EV_Ambie ODX version: 001008 Long coding: 200000 Trouble codes: No trouble codes found ---------------------------------------------------------------72 Rear Right Door System description: TSG HR Software number: 4H0959795D Software version: 0262 Hardware number: 4H0959795D Hardware version: H06 Serial number: 0000129118826 Long coding: 010F1E00400062C202083006 Trouble codes: No trouble codes found ---------------------------------------------------------------81 Gear Shift System description: GSM-LL Software number: 4H1927731A Software version: 0083 Hardware number: 4H1927731A Hardware version: H08 Serial number: SN120529 0049 ODX name: EV_GSM2x3Mono ODX version: 001017 Trouble codes: No trouble codes found ---------------------------------------------------------------88 Driver Seat System description: IVB Software number: 4H0907182H Software version: 0042 Hardware number: 4H0907182H Hardware version: H07 Serial number: 00006523046801 ODX name: EV_IVBDriveSideFrnt ODX version: 001003 Long coding: 662FF2 Trouble codes: No trouble codes found ---------------------------------------------------------------89 Passenger Seat System description: IVB Software number: 4H0907182H Software version: 0042 Hardware number: 4H0907182H Hardware version: H07 Serial number: 00006523042602 ODX name: EV_IVBPasseSideFrnt ODX version: 001003 Long coding: 262FF2 Trouble codes: No trouble codes found ---------------------------------------------------------------8F Pretensioner Left System description: RGS-VL Software number: 4H0980945B Software version: 0080 Hardware number: 4H0980945C Hardware version: H13 ODX name: EV_RGS_L ODX version: 002004 Long coding: 0006F009031F0300070308014244C8010000 Trouble codes: U111100 - Function limitation due to missing message static ---------------------------------------------------------------90 Pretensioner Right System description: RGS-VR Software number: 4H0980946B Software version: 0080 Hardware number: 4H0980946C Hardware version: H13 ODX name: EV_RGS_R ODX version: 002004 Long coding: 0006F009031F0300070308014244C8010000 Trouble codes: U111100 - Function limitation due to missing message static B200009 - Ctrl. module faulty static ---------------------------------------------------------------A9 Structure Borne Sound System description: SAS-GEN 2 Software number: 4H0907159A Software version: 0003 Hardware number: 4H0907159A Hardware version: H06 Serial number: 120619200747 ODX name: EV_SoundActuaGen2AU64X ODX version: 003010 Trouble codes: No trouble codes found ---------------------------------------------------------------BA Assembly Mounting System description: AEM - LEAR Software number: 4H0907145 Software version: 0006 Hardware number: 4H0907145 Hardware version: H05 Serial number: 97804000445104 ODX name: EV_AEMLearAU64X ODX version: 002014 Trouble codes: No trouble codes found
sydbloke
12-11-2022 03:41 AM
Haight
A6 (C7 Platform) Discussion
03-12-2022 11:03 AM
jasa004
A4 (B9 Platform) Discussion
04-21-2021 10:27 AM
Jontelito
A4 (B8 Platform) Discussion
07-19-2017 03:15 PM
Jontelito
07-19-2017 11:47 AM
