Bad Passenger side motor mount
All,
Have the 05495 code and the CE light...did a search, looked at the repair manual for this and it uses a special bracket, etc. Anyone done this on a standard lift under the car with a transmission jack or something? I have a four post lift, etc. and I haven't yet run across a procedure for us DIYers. Apologies if I've missed in in a search.
Thanks in advance for any help!
John
John
All,
John
John
What tool are you scanning with, Ross-Tech VCDS, as your code does not equate to a bad motor mount code, if you are using a generic reader you will not get to proper codes, or you mistyped the code in your post.
The motor mount codes look like this, also I do not recall a check engine light on for a bad motor mount.
17981 - Left Engine Mount Solenoid Valve (N144): Open Circuit
P1573 - 004 - No Signal/Communication
17985 - Right Engine Mount Solenoid Valve (N145): Open Circuit
P1577 - 004 - No Signal/Communication
Johnny
Sorry! Was looking at the wrong thing. It is the 17985 - Right Engine Mount Solenoid Valve (N145): Open Circuit.
I've found a decent deal on the mount, just wondering if there is a DIY procedure out there...
I'll have it scanned again at the dealer today when I'm there to pick up some other parts to see what is causing the CE light. I may be missing something. I know the place I bough the car from (not an Audi dealer) had replaced a coil...I'm wondering if that code never cleared.
John
John
John
John
Edit; you don't have to do everything I did to get at just the motor mount, I think the engine cradle removal is all you need to access it. Those bolts are on there tight, be ready for the breaker bar and maybe a pipe for added leverage!
Awesome! Thanks! I just purchased this beast last week (had an 08 S6 V10 as well a while back)...the great thing about these older cars is that there is always someone out there that has done what you need to do. Love these forums...they are invaluable and I use them for my 911 cab as well. Thanks again!!
John
John
John
John
RaiderTT2001
09-23-2016 02:18 PM
kholland
12-07-2007 12:45 PM
chimchim101
12
08-29-2007 11:46 AM
bwb
12
08-13-2006 08:13 AM
Lemon S
03-03-2003 06:02 PM
