Sponsored by:
Sponsored by:
Bought another D3 - Some faults to fix with VCDS report :)
Old 10-24-2020, 04:40 AM
Mike Freeman's Avatar
Default Bought another D3 - Some faults to fix with VCDS report :)
Dear All,
I trust you are COVID free and enjoying the rain :\
Last night I collected a very lovely LWB 2008 D3 3.0 - and as expected, I note some issues below. Any advice appreciated on any of the faults - and I'll carry on researching as much as I can:
1. Bank 2 swirl flap motor, not moving under VCDS output tests - I shall possibly open it and check the gear assembly before going any further with this.
2. HVAC. AC not working, although output tests on N280 do activate the compressor - and the low side pipe is getting cold. So mechanically ok. Any thoughts as to why HVAC is not asking for the AC? It's not on "econ". I did think temperature probes. The only bad one is in the rear footwell. Currently reporting 0C. Could it be that inhibiting the AC? Also theres rear HVAC footwell issues in general.
3. Passenger seat electrics. It was immobile, until I reached under the seat and plugged it in. Lucky or what!! It all works, aside from memory / symmetry etc, and VCDS (as you can see) reports the module "cannot be reached". This fault I'm not concerned about, but would happily try things.
4. Keyless antenna issues as reported below. Keyless not working. If anyone knows where to check? Again not concerned - but the report allows someone enough detail to advise, it would be appreciated.
5. Parking brake pads - can manage that
6. Level control. No symptoms - however am I right in thinking it has a leak thats stressing the compressor? 2 faults logged there that could be linked I guess.
7. Radio antenna - seems to work, I bet that's a headlining down job One day maybe!
Other than these annoyances (which one expects with a 12 year old D3) - the car runs great, and is a different animal to the 55 plate D3 it replaced.
Many thanks indeed,
Michael
P.S. Apologies to the D4 forum - I'm trying to remove the post I accidentally put in there before putting this here.
---------- VCDS OUTPUT BELOW-----------
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 18 19 1E 28 34 36 37
38 42 46 47 4F 52 53 55 56 61 62 67 6C 72 76 77
VIN: WAUZZZ4E57N025977 Mileage: 136650km-84910miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Cannot be reached 1100
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4E0 910 402 G HW: 4E0 907 401 D
Component: 3.0L V6TDI G000AG 0030
Revision: --H04--- Serial number: AUX3Z0G6327432
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 204F9304F3A8764438-8074
1 Fault Found:
004120 - Intake Manifold Runner (Bank 2)
P1018 - 001 - Lower limit not reached
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 136655 km
Time Indication: 0
Date: 2020.10.24
Time: 12:24:18
Freeze Frame:
RPM: 756 /min
Torque: 74.1 Nm
Speed: 0.0 km/h
Voltage: 13.68 V
Duty Cycle: 80.9 %
Duty Cycle: 88.8 %
Duty Cycle: 80.9 %
Readiness: 0 0 1 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 Q HW: 09L 927 156 A
Component: AG6 09L 3,0 TDI RdW 0020
Revision: --H01--- Serial number: 4353601
Coding: 0000001
VCID: 31696640A842CFCCA7-8064
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0007567
Shop #: WSC 02313 000 00000
VCID: 224B990CFDA464542E-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 907 181 A
Component: FBS AUDID3 H12 0200
Revision: 02005112 Serial number: AUX3Z0G6327432
Coding: 0412672
Shop #: WSC 02311 785 00200
VCID: 58BFFBE4EB78FE8400-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
4 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 197
Mileage: 133760 km
Time Indication: 0
Date: 2020.03.20
Time: 16:33:20
00183 - Interior Access/Start Authorization Antenna 1 (R138)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 53
Mileage: 135408 km
Time Indication: 0
Date: 2020.06.11
Time: 21:11:06
01176 - Key
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 96
Mileage: 135440 km
Time Indication: 0
Date: 2020.06.12
Time: 02:43:06
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 0
Reset counter: 110
Mileage: 136256 km
Time Indication: 0
Date: 2020.07.06
Time: 04:52:40
Address 06: Seat Mem. Pass
Cannot be reached
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300GY077586829
Coding: 0000002
Shop #: WSC 00613 210 91776
VCID: 3A7B416C75340C9416-806E
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000023587
Subsystem 3 - Serial number: 0131.10.060000000100010029ÿ
Subsystem 4 - Serial number: 010029ÿ
1 Fault Found:
02257 - Remote Control Receiver
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 71
Mileage: 136570 km
Time Indication: 0
Date: 2020.07.06
Time: 09:49:20
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000125169
Coding: 0084061
VCID: 1C37A7F4DFC052A4E4-8048
Subsystem 1 - Part No: 4E0 910 133
Component: FHS H03 0070
3 Faults Found:
00066 - Rear Right Footwell Heater (Z43)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 76
Mileage: 136655 km
Time Indication: 0
Date: 2020.10.24
Time: 11:55:06
Freeze Frame:
Voltage: 13.70 V
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 115
Mileage: 136655 km
Time Indication: 0
Date: 2020.10.24
Time: 11:57:42
Freeze Frame:
Voltage: 13.70 V
01593 - Heated Windshield (Z2)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 5
Reset counter: 115
Mileage: 136655 km
Time Indication: 0
Date: 2020.10.24
Time: 12:01:39
Freeze Frame:
Temperature: 20.0°C
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0143121
VCID: 3663555C412CE8F4F2-8062
Subsystem 1 - Part No: 4E2 910 113 C
Component: Wischer WWS D3 H60 0440
Coding: 00000037
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00141886
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046006 Serial number: AUZ5ZBG3447292
Shop #: WSC 00000 000 00000
VCID: 1A3BA1ECD5F42C94F6-804E
Address 0F: Digital Radio Labels: None
Part No SW: 4E0 910 563 C HW: 4E0 035 563
Component: DAB-Tuner H41 0830
Revision: 00000001 Serial number: KE1276V7300493
Coding: 0000001
VCID: 24479F14E7B06A645C-8070
1 Fault Found:
00856 - Radio Antenna
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 7
Fault Frequency: 1
Reset counter: 114
Mileage: 136650 km
Time Indication: 0
Date: 2020.10.24
Time: 11:08:35
Freeze Frame:
Voltage: 13.80 V
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H14 4210
Revision: 91H14421 Serial number: 0037P0G0F33T
Coding: 0431707
VCID: 275D88189686817C79-8072
Subsystem 1 - Serial number: 63328RB402A019167
Subsystem 2 - Serial number: 63428RB402A1D3D7S
Subsystem 3 - Serial number: 63528RB402A1D3C6R
Subsystem 4 - Serial number: 63628RB402A389F6Y
Subsystem 5 - Serial number: 63729RB402917F81Q
Subsystem 6 - Serial number: 63829RB4029131246
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0410
Revision: 00H03000 Serial number: 90026071720122
Coding: 0112241
VCID: 2643851C918C987442-8072
Component: E0221 H02 0030
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 B HW: 4E0 920 951 B
Component: KOMBIINSTR. VDO H82 0530
Revision: D05 Serial number: AUDID3G6001753
Coding: 0032413
Shop #: WSC 00011 888 06946
Address 18: Aux. Heat Labels: None
Part No SW: 4E0 910 105 A HW: 4E0 815 069 G
Component: Heizgeraet H08 0140
Revision: 0000000C Serial number: 00000009013887
Coding: 0000001
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B0771680F8
Coding: F5F9DF7F707A0E
Shop #: WSC 00408 210 91042
VCID: 6CD7B7344FE06224D4-8038
1 Fault Found:
00461 - Control Module for Seat Memory; Passenger (J521)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 71
Mileage: 136570 km
Time Indication: 0
Date: 2020.07.06
Time: 09:49:27
Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 B
Component: SG ext.Player H09 0850
Revision: 00000000
Coding: 010000
VCID: 2B5574284A6EA51C9D-807E
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000020 Serial number: 00000000057111
Coding: 0000000
VCID: 61C9D600B8223F4C77-8034
1 Fault Found:
01864 - Air Outlet Motor; Rear Right (V219)
003 - Mechanical Failure - Intermittent
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 02313 758 00200
VCID: 285F8B249B988E0470-807C
2 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 113
Mileage: 136592 km
Time Indication: 0
Date: 2020.10.24
Time: 06:52:04
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 114
Mileage: 136655 km
Time Indication: 0
Date: 2020.10.24
Time: 11:14:35
Address 36: Seat Mem. Drvr Labels: None
VCID: 55A1F2D0BC6AC3EC1B-FFFE
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 37: Navigation
Cannot be reached
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000719000069
Coding: 0036004
VCID: 1D31AAF0C4DA5BAC13-8048
1 Fault Found:
00207 - Humidity Sensor Heater (N340)
006 - Short to Plus
Freeze Frame:
Fault Status: 01100110
Fault Priority: 0
Fault Frequency: 15
Reset counter: 76
Mileage: 136568 km
Time Indication: 0
Date: 2020.10.23
Time: 23:22:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 D
Component: Türsteuer.FS BRM005 0180
Coding: 0032751
3 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 111
Mileage: 122912 km
Time Indication: 0
Date: 2019.09.05
Time: 10:23:14
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 255
Mileage: 133872 km
Time Indication: 0
Date: 2020.05.23
Time: 05:20:24
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 133872 km
Time Indication: 0
Date: 2020.05.23
Time: 05:20:24
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H08 0020
Revision: 00200008 Serial number: W040707180191
Coding: 0004861
VCID: 2A5B712C8594BC1466-807E
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H03 0120
Revision: PROD_01 Serial number: 00000000001194
Coding: 0000023
VCID: 2C5777348F60A22494-8078
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000122501
Coding: 0010101
VCID: 1E33ADFCC9DC40B40A-804A
1 Fault Found:
02268 - Switch to Deploy Display Unit
Freeze Frame:
Fault Status: 01100111
Fault Priority: 4
Fault Frequency: 1
Reset counter: 76
Mileage: 136568 km
Time Indication: 0
Date: 2020.07.06
Time: 09:49:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 D
Component: Türsteuer.BF BRM005 0180
Coding: 0032751
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 204
Mileage: 133872 km
Time Indication: 0
Date: 2020.03.23
Time: 00:00:30
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000221
Shop #: WSC 00070 000 00000
1 Fault Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 241
Time Indication: 0
Freeze Frame:
Voltage: 5.07 V
Count: 61
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000018
VCID: 29598E208092B70C6F-807C
Subsystem 1 - Part No: 4F0 941 329 D
Component: AFS-Modul links H01 0010
Subsystem 2 - Part No: 4F0 941 329 D
Component: AFS-Modul rechtsH01 0010
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 S
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396E.067535709
Coding: 0000001
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000010016
Shop #: WSC 00976 210 83219
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 330421L277
Coding: 34453039313531303541205641303333303432314C323737
Shop #: WSC 79937 007 01254
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032751
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 S HW: 4E0 035 753 A
Component: SDS 3502 UK H46 0630
Revision: 00000000 Serial number: 00000809030007
Shop #: WSC 12336 024 394758
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J7710AB
Coding: 1020403
VCID: 5CB7E7F49F4012A424-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032751
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08730720212561
Coding: 0221008
VCID: 23459C08E2BE6D5C25-8076
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 04:42)--------------------------
Old 10-24-2020, 06:21 AM
AudiWorld Wiseguy
dvs_dave's Avatar
Most faults logged are historic, so really just noise. Look at the dates/times.
Do a full reset and then drive the car for a while to get a log of current faults.
Old 10-24-2020, 10:18 AM
That's fair enough - I'm having issues clearing the DTCs actually. Seems to only work if I enter the module first but not from the auto-scan menu.
The date/time was also wrong, although I corrected that.
I'll try to clear it again and repost accordingly.
Mike
Old 10-25-2020, 06:56 AM
ltooz_a6_a8_q7's Avatar
I wouldn't take the vcds report religiously unless you like to replace good parts. All A8 components are in a controlled system and one failed all will show up on VCDS, make sure to understand and verify the defective parts before replacing them.
Old 10-25-2020, 07:50 AM
Yes agreed and understood - a lot fewer errors exist now I have manually removed the DTCs and rescanned (see below).
I have resolved the inlet motor issue (hopefully), and hoping it stays fixed. I'll buy 2 glowplugs.
My priorities now are only really:
1. The aircon - and why it doesn't function (along with the rear footwell heaters, both seem dead). compressor works under output tests, and low side pipes get cold. No errors on VCDS to help steer me.
2. Passenger seat module (cannot be reached)
Many thanks indeed for any potential advice before I return to the car.
-----SCAN BELOW----
VIN: WAUZZZ4E57N025977 Mileage: 136690km-84935miles
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
0F-Digital Radio -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
Address 01: Engine
Cannot be reached
Coding: 0000001
Coding: 0007567
Coding: 0412672
Component: ELV XXXX
Cannot be reached
Coding: 0000002
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 79
Mileage: 136690 km
Time Indication: 0
Date: 2020.10.25
Time: 15:32:38
Coding: 0084061
Coding: 0143121
Coding: 00000037
Shop #: WSC 02313
Coding: 00141886
Shop #: WSC 02313
Coding: 0000001
Coding: 0431707
Coding: 0112241
Coding: 0032413
Coding: 0000001
Revision: 00000000
Coding: 010000
Coding: 0000000
Coding: 0015510
Part No: 4E0
VCID: 29598E208092B70C6F-FFFE
No Faults Found
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H49 1060
Revision: 00000000 Serial number: 364FW077686133
VCID: 3B7544687A0E359C0D-806E
Part No: 4E0 910 135 A
Coding: 0036004
1 Fault Found:
006 - Short to Plus
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 79
Mileage: 136688 km
Time Indication: 0
Date: 2020.10.25
Time: 15:38:00
Coding: 0032751
Coding: 0004861
Coding: 0000023
Cannot be reached
Coding: 0032751
Revision: --H03---
Coding: 0000221
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 241
Time Indication: 0
Freeze Frame:
Voltage: 5.07 V
Count: 61
Cannot be reached
Coding: 0000001
Coding: 0032751
Cannot be reached
Coding: 0032751
Coding: 0221008
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 B HW: 4F1 862 335
Component: BTA H11 0900
Revision: 00H11000 Serial number: 00000007595591
Coding: 0070001
End-------------------------(Elapsed Time: 08:17)--------------------------
Old 10-25-2020, 08:05 AM
The AC is easy and simple. Don't monkey with the VCDS and break it by changing the preset program. Check out my posts on how I fixed my AC in the signature. My simple fix without all detective work turned out the G65 and a full vacuum and recharged to the specs. It's still working perfectly after many years.
Old 10-25-2020, 09:07 AM
Thank you. I have searched, and read, and watched your video. Much appreciated.
My only concern is that my ECON setting doesn't keep reverting to "on" - and my AC does seem to work using the output tests. Could it still be the G65? As I could be risking a lot of work stripping down the front end if that's not the issue.
Any thoughts welcomed. Thanks again.
Mike
Old 10-25-2020, 10:54 AM
That's exactly what happened when my G65 failed, would NOT get out of econ mode LOL.
https://www.dognmonkey.com/audi/what...ac-system.html
https://www.dognmonkey.com/audi/high...s-hot-air.html
Old 10-25-2020, 12:09 PM
You misunderstand me - mine is happy staying OFF. It's not enforcing ECON. The low side pipe is also cold on the "black pipe section"... indicating it's working a bit?
But yeah - I'm a bit lost with it. I might let the shop look next.
Old 10-25-2020, 12:28 PM
Be careful when taking to the shop, they may base on the VCDS printouts and start shotgunning parts on your expense.
If it doesn't get on the econ mode then that's a new one to me. Get your self a manifold, a vacuum and some Freon, start evacuation, test for leaks, then recharge, it only takes 20oz and 2hr of work. I never believe the system just dies overnight.
Quick Reply: Bought another D3 - Some faults to fix with VCDS report :)
