Can someone ID these components please
I believe the unit on the right is the water pump but would like confirmation. Also what is the item on the left please. Thanks in advance.
![](https://img.photobucket.com/albums/v310/TheSimps/null.jpg)
Of course! Thank you. 1st time I've been under the car today. I was surprised to find the air ride compressor in the wheel arch, I was always under the impression it was bolted to the engine.
Forgive me if you're talking about something else,
but the secondary air pump is used to blow clean air into the exhaust system to help burn any unburned fuel and clean up the remaining gases to produce cleaner emissions.
I'm not sure if it's added pre or post catalytic convertor? I would suggest pre, but downstream of primary O2 sensor.
Depends on what part of the SAI is broke. You might experience a rough idle at cold start up and then nothing after that. Scanning the car should be able to tell you whats not working.
audifirst
04-16-2008 02:59 AM
gadgetmeister2711
2.7T V6 Discussion
10
11-30-2007 03:46 PM
hsjb
06-25-2003 10:14 AM
